diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > ESLs, planars, alternative technologies
passive line level volume control - Click HERE for Original Thread
CharlieM
Can someone recommend an inexpensive passive type line level volume attenuator for a bi-amp application? I'm wanting to bi-amp my planned esl and I have two amps and one preamp. Neither amp has a gain control and the preamp doesnt have separate gain controls so I need some way to balance things out.
I'm thinking I don't need a line level amp, just a pot in the line to crank one amp down. Any suggestions to a newbie with no electronics experience?
Charlie
cuibono
I'm not real clear on your setup, but if one speaker always has the same volume relative to the other, I'd use a permanent voltage divider - just two resistors in series to ground. The input goes in at the top, the output from the junction of the two resistors..
google 'voltage divider'...
Page generated in 0.016359090805054 seconds with 16 queries,
spending 0.00768232 doing MySQL queries and 0.00867677 doing PHP things.
