diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
alesis Quad reverb - Click HERE for Original Thread
burnedfingers
I am trying to locate information so that I might try to repair a friends Alesis Quad Reverb digital effects processor.
I am told it will not remember anything put into memory.
Does anyone have any suggestions? Links to a schematic? Ideas?
pinkmouse
You mean Quadraverb, yes? ;)
IIRC, it has a small memory back up battery located somewhere just behind the display on the PCB. Swap it out and you should be good to go.
edit: yes I know...time!
burnedfingers
Thank you Sir!
As soon as I get my hands on it I will replace the battery.
pinkmouse
It just occurred to me re. the position of the battery backup that I might be thinking of the SPX900. Same era, and I've fixed both. Principle is the same, find it and swap it out ;)
GeertSlootweg
Yep, info is also to be found in the user reviews of www.harmony-central.com. 2c.
Page generated in 0.021023035049438 seconds with 17 queries,
spending 0.00874734 doing MySQL queries and 0.01227570 doing PHP things.
