diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
Fender Champion 110, upc1188 - Click HERE for Original Thread
drummer_Dave
Hello all,
So here's my dilemma, hope someone can help
I recently acquired a Fender Champion 110 guitar amp, that didn't turn on. After i tore it apart and couldn't see any burnt components i needed to isolate the power supply from the rest of the components so i removed all 5 op amps and put dip sockets in. now the only thing connected to the power supply was the upc1188 20watt power amp chip i powered the unit up and the transformer started buzzing (from what ive found this usually happens when you ground a tranny output) so i shut of the amp and found that one of the 1n4003 bridge diodes was conducting both ways, so i replaced it and the unit powered up fine. Great, or so i thought
I still dont get an output signal, i found a copy of a Fender champion 30 schematic ( http://www.manualnguide.com/dl/10166/ )which is almost the exact same (except for the power out chip which id a tda1514). so basically I am sort of at a point were i think i need a upc1188 chip (or the proper schematic). Does anyone know where i can get one or 2 of these chips? or i also have a second option. I could always build a kludge board (26v rails) with a lm3886 chip i have lying around and interface that with the existing circuit.
Any help in sourcing parts or schematic would be greatly appreciated.
Dave
drummer_Dave
well after i reverse engineered the power amp section and figured out what was wrong I ended up finding s an electrolytic cap in the signal path was dried up. Who uses electrolytic in audio signal path??? urg) i then found the schematic of the whole amp tucked inside the amp. so if anyone need the schematic email me and i will scan and email it.
Dave
Nigel Goodwin
quote:
Almost every solid state amplifier ever made? :D
Geek
Hi Dave,
...an electrolytic cap in the signal path was dried up. Who uses electrolytic in audio signal path???...
Sounds to me like you need to join the tube amp crowd ;)
Cheers!
drummer_Dave
I agree geek, once i finish off my digital matrix mixer i plan to do a nice 15 - 20 watt tube amp (never dealt with tubes before so im sure there will be a lot of searching in this site) fortunately a guy i work with (who is 70+) has a whole pile of tubes and transformers i can have, i just have to sort through them, but thats a whole nother thing for another day
Dave
head_spaz
I see that you've already fixed your amp, but if you still want to pickup
a few spare ICs, tubesandmore.com stocks them.
Look under the Solid-State-Devices / ICs / Fender category.
IC - ORIGINAL FENDER, POWER AMP PC1188H
Part Number = P-QPC1188H
2007 Catalog / page 68
Price USD = $10.25
drummer_Dave
thanks for the heads up head_spaz
Dave
Kenda47
Hi Dave
It looks like you solved your problem. I have been asked to see if I can repair my friend's son's Champion 110 but the amp is pretty fried in the output stage area and with no schematic I am struggling to know what the components should be.
You mentioned that you can e-mail a schematic for the Champion 110. If you still have one I would be very grateful.
Thanks for your help.
Cheers
Keith
drummer_Dave
yep i got the schematic at home, Ill try to scan it and email it within the next day or so if you can be patient...
Dave
Kenda47
Cheers Dave that would be great. Thanks alot. I notice you are thinking opf buildiong a valve amp. This is my forte so if I can help let me know.
Keith
gypsypunk
hi
please could you help me i have been meaning to get my little champion 110 amp fixed up as i have had it so long with a broken input jack and the drive has kaput
any chance of a copy of the schematics
i would really appreciated it
victorjones@hotmail.co.uk
drummer_Dave
sorry for the delay all, scanner was down. pm me with your email so i can attach the file and send it to you.
Dave
drummer_Dave
gypsypunk i tried sending the file to you at
victorjones@hotmail.co.uk but i got a delivery failure, any other email's i can try?
Dave
kingmattress
Dave, I am also working on a Champion 110. Pretty nice little amp. I would really appreciate it if you would send the schematic my way. I may have damaged a pot trying to put a knob on. The flat on these pots are opposite the other amps I have like this. The pots are also not attached to the face plate, just the board. I also need to order a new jack and I need the part number. Thanks!
drummer_Dave
Pm me so i can get your email, once i get that i can send it on to you :)
Dave
Page generated in 0.065637111663818 seconds with 17 queries,
spending 0.01061225 doing MySQL queries and 0.05502486 doing PHP things.
Please support our sponsor.
