diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
worth building a PS or Voltage Doubler for this amp? - Click HERE for Original Thread
DJNUBZ
I was wondering how hard it would be for someone to build a PS or possibly a very simple voltage doubler to get this amp module to work in a car?
http://www.diyaudio.com/forums/show...threadid=111147
It would seem to me like a worthwhile venture if it could be done cheaply for anyone who wanted multiple ch. of amplification in a car.
MikeHunt79
Depends. I've got that exact same amp module, and of you need the extra power, go for a doubler.
I managed to use the SMPS from an old broken car amp that gives out ~24v on each secondary, so I'm planning on mounting the sure module in the car amp case. I've tested it and it works real well.
That being said, if you don't need more than 30 or so watts per chan, just hook it up with no doubler, and you're set.
If you wanted to design a doubler from scratch, things may be more difficult - I recommend a push-pull design, make it so it will handle 10 amps or so and you should be good. :)
Page generated in 0.019316911697388 seconds with 17 queries,
spending 0.00751519 doing MySQL queries and 0.01180172 doing PHP things.
Please support our sponsor.
