| vangelis |
Hi, friends!
Anyone have Randall rg100sc schematics?
Thanks,
Oly |
| vangelis |
Again,
:bawling:
Somebody of you have schematic or service manual for
Randall rg100sc
thanks |
| mensur |
| Imam ja zemo,imam ja!!! |
| Cal Weldon |
Hi mensur, if you wish to post in another language, please also post the same in English. The moderators do not speak Serbian. :)
Thank you. |
| mensur |
ok,sorry.
I ment to say, I have it.PM me.
Bye. |
| vangelis |
| quote: | Originally posted by mensur
Yeaaaaaaaah!!
:worship: |
| Joe406 |
| Can you send me the schematics too? I have one that is giving me no output. I have power though. |
| vangelis |
| quote: | Originally posted by Joe406
It's it... |
| Raddion |
Hi I was wondering if you ever found the schematic for the RG100SC? I downloaded the one linked to above, but it seems to be a schematic for a footswitch? Thanks.
Broken in CT
| jakeweber |
| Having the same issue. Getting a hum from the amp (power). No output. The amp has over time started to show this issue. It has finally stopped responding to any signal. I'm hoping its a solder issue on the input jack? If anyone has the solution to this issue or could shine some light on what may be causing the issue, it would be greatly appreciated. Thanks! |
| dB AudioTech |
| quote: | Originally posted by jakeweber
Try patching a cord from the Effects Send to the Effects Return. If that makes it work, either use a good contact cleaner to clean those jacks and cycle the plug in and out. Often just sticking the plug in and out a several times will fix it, but it will recurr sooner.
-Dave |
