diyAudio.com diyAudio Forums Archive > Top > Market Place > Parts and Supplies
Building inverter using ETD 59 ferrite cores - Click HERE for Original Thread
xyz9915
I have some pieces of ETD 59 ferrite cores and I want to use them to build an inverter. Following are the details"
Input voltage : 13.2 to 10V DC (Center tapped)
Input current : 40 Amperes
Output voltage (1) : 240v Ac
Output voltage (2) : 15v Ac
Output current : 3 Amperes
operating frequency can be 20 to 30 KHz.
please provide turns ratio and other details for making an inverter. Or other ETD ferrite core can be proposed if applicable. I;ll use SG3525 IC for building the inverter.12
Page generated in 0.02390193939209 seconds with 17 queries,
spending 0.00967979 doing MySQL queries and 0.01422215 doing PHP things.
