| rtarbell |
Hello all,
I have an old EI core transformer encapsulated. The case itself is fairly dirty - rust flakes, and general grime. What is a good way to clean it? |
| richie00boy |
| Cloth dipped in cleaner of some kind. IPA is good, soapy water may do. |
| dhaen |
In the past I've used a wire brush to good effect.
Not sure the water is advisable... |
| Nordic |
| WD40 is great for cleaning surfaces with old grime, on some transformers the case is only held with some bendoverclips at the bottom... I take em off and give them a quick coat of matt black from a can before reassembly... |
