diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
6 Channel Class D? - Click HERE for Original Thread
AudioX
Hello, I have been biten by the Class D bug. I would like to build/ Buy a CLass D amplifier that is capable of driving 6 channels. Would it be better to buy one (if avialable) or just build it?
Can I get some opinion from the Class D gurus?
SQ Kid
I'm doing it the semi-easy way. Check out the sure electronics 4ch class d amps. i bought two so i could power a home theater setup. lower cost as well for a beginner (much like myself)
BWRX
quote:
That depends on a lot of things: budget (a big factor), desired power per channel, etc.
ttan98
If you have highly efficient mid range, > 90db then
get 4 channels, T-amp type, 10-12 watts
for mid and tweeter
2 channels, ? high powerd type, 50-200watts
for woofer.
there are lots of info here, spend some time searching and lots of reading, then ask specfic/detailed questions.
cheers.
BTW I am using a T-amp driving my full range speaker(>92dB), sound pretty good and loud enough.
Page generated in 0.024715900421143 seconds with 17 queries,
spending 0.01114798 doing MySQL queries and 0.01356792 doing PHP things.
Please support our sponsor.
