diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Pearl enclosure and power supply? - Click HERE for Original Thread
Boban
I am wondering what type of enclosure is suggested for Pearl. I looked at Hammond cataloque (aluminum boxes) but couldn't find anything suitable. Any suggestions?
Second, can I increase value of the ps capacitors without compromising anything (or much). I am thinking of using 22000uF instead of suggested 10000uF in the power supply (fig 4 in the manual).
Boban
transducer
Hi Boban,
I'm in Toronto as well, and have built a lot of electronics and speakers. I'd love to hear the Pearl (thinking of building it or the Ono). I can offer you some help, seems like this is the first time you've built something, and maybe then you'd let me use your Pearl in my system to test it?
What exactly did not work with the Hammond enclosures? I can suggest some other places to look as well.
Ron
Boban
Problem with Hammond is that I could't find enclosure with the dimensions I like. The ideal (for me) would be something like 11x10x3.
Boban
transducer
Check at Supremetronics, on Queen St. W. just east of Active Surplus. They have different size enclosures, one might fit. The other place to check is on Victoria Park, across from Sayal, near Electrosonic. I can't remember the name, but if you look for Sayal on Vic Park just south of Steeles, and then cross the street to the west side and go north about a block, there's a strip mall, there's a parts and computer store that carries enclosures.
Ron
transducer
Hammond aluminum enclosure, 12x10x2", part no. 1444-29 and bottom plate 1434-29. If you don't need the height, this could work. The tallest thing is likely your tranformer, maybe the ps caps, they should fit. The caps can go on their sides if need be.
Ron
Boban
Yes, you are correct. Caps are problem and that's why I am looking for something taller than 2 inch. Will check the places you've recommended.
Boban
Saurav
Go for 3" depth, you'll need it with the PCB standoffs and the electrolytic caps.
I used a Hammond 17x10x3 chassis (if I remember right). Worked out fine, because I recently got a new MC cartridge, and there was room left over in the chassis for the step-up transformers so I didn't have to add extra RCA connections to the signal path.
P.S. I built an outboard power supply, in a cheap Radio Shack enclosure, so I didn't have to fit PS transformers inside the main chassis. If you're building the Pearl in one enclosure, your height requirements might change.
Boban
Thx Saurav,
what about the umbilical cord?
Saurav
I think I tried multiple options, and then ended up with some multi-conductor cord I bought somewhere. I know that thicker gauge would be better for the power and ground lines, but it seems to work fine, and the hum levels are acceptable in my system, so I haven't bothered with trying to improve it. I bought male/female DIN connectors and soldered 4 of the conductor wires in the cable to 4 pins on the DIN connector. I think my cable is shielded, and off the top of my head I don't remember if I connected the shield at one end or both ends. I was battling serious RFI problems at one point (after I rewired my tonearm), so I was trying everything I could think of.
PaulyG
I built a combination of the pearl phono section and the Aleph L as my line preamp. The preamp sounds great! I used enclosures from Par Metals in NJ (one for the power supply and one for the electronics). Par has some nice 19" rack mount enclosures at very good prices. I do not know if they export to the Great White North, however (although I shouldn't talk as it is pretty snow-covered here in Connecticut).
-Paul
http://www.par-metal.com/
PaulyG
BTW, I used good old 9 pin RS-232 connectors and 22 ga wire that I enclosed in heat shrink. Do not have any problems with hum. Just make sure that the end that could have power is aways female so there is no chance of electrical shock:bigeyes: (female on the output from the power supply to male on the umbilical cord input to female on the unbilical cord output to male on the preamp input)
vpharris
I used some "plain Potatoes" boxes as seen here, painted black and with a front panel added. I bought them from Mouser. The larger one is 8in.Wx12in.Dx3in.H. Fit is snug, but works. I didn't really like leading the connections from the one channel past the electronics for the other to the back, but it worked ok. Now that it's done, I'm pleased with how it turned out.
For the umbilical I used a DIN connector. I think I used 5 pin; one unused. They're very inexpensive. A couple of dollars for both parts. Looks professional (the connector, that is) and works fine.
vpharris
vpharris
Peter Daniel
Kimber 4TC speaker cable (8 wires) makes a nice umbilical cord. I tested it in my gainclone and it sounds very good with extended and detailed top end without coloration added by some lesser wires (like silver plated copper in teflon jacket that I also tried). Some may doubt it, but umbilical cord from reg PS has an influence on the sound of your preamp.
moe29
vpharris,
that's some really nice work!
Saurav
Hi Vince,
Nice looking work. Where did you get those decals for "input" and "output"? I think I've seen something like that at Radio Shack, but never pursued it. Did you just print them yourself onto adhesive backed transparencies?
Boban
Vince,
very nice job. Hope to have something like that at the end.
Peter,
do you know where to get Kimber cable in GTA?
Boban
Peter Daniel
Partsconnexion, of course.;) If you are in a hurry, you can made the order by phone and pick your stuff the same day from Oakville location.
You might also try Bay and Bloor Radio or Brack's downtown. Another nice store is Great American Sound on Queen, around Bathurst. Great place for used equipment, but not really cheap.
vpharris
Thanks for the comments, guys.
The lettering is simply rub-on dry transfer letters available at hobby stores, art supply shops, good stationary stores (I think they may be all gone though:bawling:). Letraset is one brand.
Saurav
Thanks. If you used individual letters, you did a really good job of lining them up :)
Page generated in 0.043009042739868 seconds with 17 queries,
spending 0.00774145 doing MySQL queries and 0.03526759 doing PHP things.
