diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
giant BIB audio nirvana super 8 - Click HERE for Original Thread
nirvana
90" x 11-1/4" x 18-3/4" deep
nirvana
nirvana
last one
seventenths
Wow!, but I almost wish you hadn't done that! What are your listening impressions?
7/10
nirvana
wonderful mid, open sound ( very high....) , dynamic ,powerful,
very good bass, much better than my double bass reflex.
thank you Zillaspeak.com !!!!!
:wave:
gychang
how is the high freq of the speaker?
cymbal music etc...
gychang
nirvana
this speaker is good to 19K hz or 20K.... it's anough for me.
cristaline high... no sub no filter no tweeter
at this price, audio nirvana super 8 is fabulous. Great sound.
my dream : Supravox or Fertin but .... a lot of $$$ for just little bit more I think.:hbeat:
OzMikeH
If it was any bigger you'd have to stand on chair to listen or fold the top over so it fits in the room. :D
Painted the same colour as the wall it would have a higher WAF than many smaller boxes.
There is certainly no possibility of china dolls or doilies on top with this design. She would only try once. <THUNK> <tinkle>.
I like it. Nice job.
seventenths
Well, they look great and I'd love to get an idea of the bass response vs. my 166 BiBs.I've wondered about the possibility of dropping the high point of the baffle 6-8" and adding a K-slot to the back of "Bigger" BiBs to lower the driver. The driver position for my 72" cabs is pushing it a bit as is...
Oh and 18K? Fine here as my latest test tone adventures tell me my OEM equipment is only good to 15K. My 15 Y/O daughter assures me that the higher frequency tracks were indeed audible :)
7/10
MIKET
Do you have plans for the 8" Nirvana BiB, this looks like an interesting project to use with my 8 watt SE amp.
gychang
anyone know, or Scottmoose?
I am biased to Chang cabinet... I am intrigued by Super nirvana 8 (in part due to sensitivity without needing a separate tweeter, in contrast to Pioneer 8") for use in possible double vent cabinet. Like the Nirvana style better than the FE207E
Any of the cabinet designs in the spawn page appropriate?
thanks in advance.
gyCHANG
Scottmoose
It'll go into your existing boxes, but with ~4ohms of series resistance, which will lower their efficiency. I mentioned it in your build thread actually, though it got lost amongst everything else, as often happens in longer threads: http://www.diyaudio.com/forums/show...999#post1286999 They'll also go in Sachiko, though they won't have as much LF gain as the 206 I designed it for due to their much higher Vas.
Problem with the AN drivers, IMO, is that although good, they aren't as good as the Fostex equivalents, and they really aren't much cheaper either. That's why I've never bothered coming up with any dedicated cabinets for them. The interesting ones in the AN range to me are those that have no equivalent from anyone else -the cast-frame models, and the 10in driver. I've yet to figure out a use for the 12in driver -it needs such a gigantic cabinet for decent performance (~20 cubic foot) that it seems a bit pointless.
Hope you're still enjoying your existing cabinets BTW?
FWIW, if you're after greater efficiency / detail etc., easiest way forward would be to swap out the Pioneers for a pair of P10 FE207eNs. As you like the AN style, you could get a pair with black coloured cones, plugs etc.
DaveCan
Great looking cabs Nirvana!!!
I had an idea while looking at your cabs, first I thought if they were flipped upside down the driver height would be a little lower, then I discovered that by the time a stand was made to lift the cabs up off the floor it would end up being the same height anyway:xeye:
So then I thought, if a person knew the listening position they'd be sitting at you could make a wedge baffle, so that the drivers would be angled down a few degrees and focus more toward the ears at the listening position instead of up and over in stock form.. Maybe this could help compensate for the high driver position on the bigger BIB cabs?? What do you guys think??? Dave:)
gychang
Looks like Audio Nirvana speakers are out. You are referring to FE207E that has been souped up by Dave??, plugs and Enabled?
We have moved to much larger house and now settled in. I listened to my Chang cabinet every night, play Flac files, little bit of addiction...
With my amp32 (t-amp) clone, it is clear, full sound, satisfying extended bass, all important midrange is fantastic. Tweeter adds ideal amount of sparkle. The cabinet appearance is fantastic IMHO, design inspired by experts here (u know who u r), and my clumsy woodworking with a router and circular saw looks more than satisfying.
When I want to let it all "hang out", i.e. play loud, I get clipping, particularly with fast transients. To achieve true audio nirvana (pun not intended), I am thinking about higher rated amp, more likely I will build another Chang cabinet with the FE207E, will see.
Hope enjoy the pictures.
gychang
Scottmoose
Nice shots. :) Glad you're still enjoying them.
Yes, the drivers are modified to such an extent over the original base units they get the new name. A quantum leap forward over the B20 (good though it is for the money) & a goodly amount of extra sensitivity too.
GM
quote:
.......so that the drivers would be angled down a few degrees........
Indeed!
I periodically mention my preference to having the 'fullrange' drivers, mid/HF horns above my head a bit and angled down as it reduces early reflection energy and gives me a presentation more like I get at a live venue.........
GM
Godzilla
Anytime Nirvana. Enjoy your speakers!
Gychang - looking good too! Nice room. I am also interested in the 207 lately. Chang, Half Chang or even simply in a large ported box. There is a recent thread on optimizing a tweeter/crossover possibly using the $36 tweeter. I will follow with interest because i think this would be an amazing combination especially in a good box... maybe the ultimate compromise using a full range driver.
Hi Scottmoose! I never heard the AN drivers but i bet they are not half bad based on spec, looks and purpose for which they are built. May not be as good as Fostex (not much is!) but probably just a varying degree of 'good.' I don't own them but respect the folks who want to save a few $$$, have some full range fun and save a few bucks in the process.
Lately, i have been enjoying my new iTouch wifey got me as a present. Great sound and so many hotspots in NY that i only occasionally cannot get onto the web - and read thru this forum! Also, the iTouch sounds better connected to my stereo than my laptop. I am pleased with it as another way to enjoy great sound.
despotic931
what kind of cabinet would the AN Cast 10 excel in?
Nelson Pass
quote:
Very excellent.
Scottmoose
quote:
On a very quick look at the specs, a decent BR or BVR would appear to be a good choice. It'd actually squeeze into Chang, though ideally it would prefer a larger volume to improve LF gain, and a few tweaks to kill the unwanted resonance at 575Hz, as you can see:
quote:
Originally posted by Nelson Pass
Very excellent.
Agreed. I want a couple. :)
Godzilla
Scott, is that the response produced by the AN BIB? It doesnt have the wiggly jigglies all the others do?
Godzilla
Scottmoose
Nah, it's in the Chang cabinet refered to above.
DaveCan
quote:
Originally posted by GM
Indeed!
GM
Totally agree, I think the ticket with the larger BIB cabs to overcome the high driver height would be to mount the driver to an angled baffle that aims the driver down a few degree's towards the listening chair. I never thought of that till recently, but seems so simple and now the problem is solved possibly ,when using the larger drivers.. Dave:)
Page generated in 0.064575910568237 seconds with 17 queries,
spending 0.00906324 doing MySQL queries and 0.05551267 doing PHP things.
