diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Charlize 2, no input caps, HISS - Click HERE for Original Thread
Code
Having just bought a Charlize 2 (diyparadise.com) I'm experiencing a huge amount of HISS when the amp and the source are connected to the same mains ring.
At the moment I'm running a huge extension cord upstairs which is far from ideal!
Is a ground loop isolation transformer a potential solution?
Ian
Code
Maybe a picture will help
http://www.pix-hoster.com/img.php?id=2008_0f66
Lostcause
Sorry code, the only way to stop it is to have completely isolated grounds, I put my source on a battery to achieve this.
Isolation transformer? no idea if it will work but I'm sure someone will be able to comment.
theAnonymous1
Or disconnect the mains ground from the two switching supplies. You should then connect the mains ground to the chassis for safety reasons, making sure the supplies/amps grounds are isolated from the chassis.
Code
quote:
Sorted! thank you! : )
Page generated in 0.022512912750244 seconds with 17 queries,
spending 0.00861716 doing MySQL queries and 0.01389575 doing PHP things.
