| lovelikecute |
hi! It's my first posting... :att'n: :att'n: :att'n:
I'm (not good) korean high school student. - who cares? -_-;;;;;;
:att'n: :att'n: :att'n: :att'n:
anyway... I built 6 input amp with LM3886 - for small band group
and I need output ports. and searched DIY schematic.
but there isn't.
Y cable maybe harmful to sound quality, so I need help///
please give me a good schematic but easy to build and cheap...
p.s. In this case, may I use a y cable?
:hot: |
| Brion55 |
Not real clear what it is you are wanting to do. You made a small mixer / amp right? Are you wanting to simply output the mix signal? If so, that should be simple enough. Please give us a little more information and perhaps one of us can help.
Edit to say: If you could include a schematic of the mixer / amp it would help. |
| lovelikecute |
I made 6 input amp with this schematic.
SO, Each of six amplifier had made and connected parallely. |
| Brion55 |
If I understand your drawing correctly, all 6 amps are tied to 1 output jack? I assume this goes to some kind of speaker system?
What exactly do you mean by "output ports?" Do you mean line level outputs? Or are you trying to run multiple speakers? |
| lovelikecute |
I think it may be a speaker - difference is not a speaker but small preamp.
my friends - band club wants 6 output port for link small preamp
thanks for concern about my project. |
| Minion |
| Are you saying you want a Preamp with one input and 6 outputs?? |
| lovelikecute |
| Yes! 99.6% is corresponding! |
| Brion55 |
| I think this is what you are wanting - 1 line or instrument level input & 6 line outputs. |
| lovelikecute |
thanks a billion
god bless you!!!! ¤Ð_¤Ð |
