diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > ESLs, planars, alternative technologies
Need your ideas for ES headphone cabling - Click HERE for Original Thread
j beede
I have decided to add grounded aluminum stator shields to my ES headphone element "stack up" for safety reasons. This means means I need eight conductors to service the stereo pair. I am running my dc bias at 550 or 825 VDC with 1:60 step up for the audio signal. Any one have suggestions for obtainable ribbon or jacketed wire that would be mechanically flexible enough while standing off these voltage levels?
...j
Ed Holland
One thing I might suggest is instrumentation wire, with a silicone insulation. Its often sold as extra flexible wire etc.
Your difficulty might be in keeping weight down, since higher voltage rated insulation tends to be thicker. With 8 conductors this is likely to add up.
A quick search of mouser, Newark etc. only turns up bulk quantities, e.g. 100 foot reels - not really what you want...
Ed
Ed Holland
These guys seem promising - maybe worth a query to them:
http://www.flexiblewireandcable.com/
They have some flexible, HV rated stuff that might work
Ed
arend-jan
ER Audio sells nice thin flexible HT wire in different colors.
Page generated in 0.028994083404541 seconds with 17 queries,
spending 0.00886559 doing MySQL queries and 0.02012849 doing PHP things.
