diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
TL 072 replacement for MM 100b - Click HERE for Original Thread
voxac30
I rebuild my 23years old MM 100b bass amp -hybrid preamp
ic and poweramp tubes (6l6GC ) . I would like to know
to replace ic TL072 with another ic with less noise and more
dynamic for better sound . Thanks for help !:confused:
Chucko
The TI OPA2134 is a good choice. But it takes more than twice the current of the TL072, so be sure the power supply is up to it.
Nigel Goodwin
The TL072 is a great opamp, I wouldn't have thought replacing it will make any difference whatsoever? - it's probably already by far the highest quality part of your amplifier.
Brett
quote:
I could not agree less.
tINY
The TL072 is fine for bass amps. Lowering the noise is a little harder than just replacing an op-amp.
But, if you think it will help, you could try an AD823. Make sure the supply is adequate (as it draws more quiesent current) and be prepared to alter the feedback a bit as it has almost 2x the slew rate as the 072.
-tINY
Page generated in 0.020829916000366 seconds with 17 queries,
spending 0.00722075 doing MySQL queries and 0.01360917 doing PHP things.
Please support our sponsor.
