diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
PGA2310 vs. PGA2320 - Click HERE for Original Thread
error401
Does anyone know why TI released the PGA2320? In all respects except voltage swing, it seems very slightly worse than PGA2310. Am I missing something here, or did TI just move the chip to a different fab process or something with slightly different specs?
Obviously they're both very good, it just seems odd they'd relesae a new part number with almost identical (and slightly worse) specs across the board. Any ideas?
DVBjunky
I was told they changed some little details in the productions process and so PGA2320 offers in Realworld less THD - as you can see in the datasheet.
Someone claimed "better matching". At least its a later revision of the PGA2310 i did stuck with it and building an PreAmp and a headphone amp with it.
If you dont use a buffer (input) you can use PGA2320 due to the high swing rate - if you are planning to use Input buffer and output buffer...than use PGA2311 because its need lower voltage 5V.
reagrds
Ayk
gfiandy
I was told by our distributor that the PGA2310 was designed for a process that TI do not have a fab for so it has to be subbed out.
The PGA2320 was a redesign to work on a process for which TI own a FAB. My experience is that despite the specifications the PGA2320 sounds slightly better.
Andrew
Page generated in 0.019062995910645 seconds with 16 queries,
spending 0.00859499 doing MySQL queries and 0.01046801 doing PHP things.
