| prorms |
is thier away get ride of the hum and hiss in this fuzz schematic?????
it just a simple fuzz stomp box schematic
when you turn up 3/4 way gets realy bad |
| poobah |
I can't speak to the hiss... but the hum is coming from your guitar or the environment.
The circuit MAY be happier in a metal box.
As far the the guitar is concerned... that's why they make humbuckers...
| Geek |
Emitter-to-ground for a 2N5088 is baaaaad. Their beta is way too high (I've measured them up to 600!). You need an emitter resistor (bypassed) to control it. That'll drop your hiss by a good 20dB+.
Also, you want your output cap on the other side of that 1K resistor and reverse the polarity of both the input and output cap.
Cheers! |
| karahara |
You might know this site: Generalguitargadgets
There are some good infos and schematics.
With a fuzz you'll always have a lot of noise and hiss. You could use a noise gate to have silence while not playing. |
| tINY |
Without and emitter resistor on the first stage, you're probably loading your guitar pick-up down pretty hard too.
With an resistor of 750 - 1.5k on the emitter, you'll have a lot higher input impedance.
-tINY
