diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
output tranny for 6AK6 - Click HERE for Original Thread
PRNDL
I'm converting an old Mono amp into a tube guitar amp.
Originally the amp used two 35C5's in push-pull.
The new amp uses one 6AK6 in single-ended.
Can I use the output transformer in the new amp?
35C5 has plate R = 13K and load R = 2.5K
6AK6 has plate R = 200K and load R = 10K
My guess is that this would be fine if I cut the center tap (2.5K + 2.5K), or I could use a Fender Champ OT (6V6 at 5K).
Is this correct?
Thanks!!
PS
That doesn't sound right at all! I reasoned that 6AQ5 and 6AK6 are similar tubes, with the former equivalent to a 6V6.
tubewade
The biggest problem with doing that will be saturation of the core in a transformer without an air gap. It shouldn't damage anything, but I wouldn't expect the sound to be very good either.
Also, if the transformer is 2k5-0-2k5, and you neglect the centre tap, it won't be 5k. You have doubled the turns ratio which quadruples the impedance ratio. You would then have a 10k primary.
Tom Bavis
Push-pull 35C5 or 50C5 will probably use 4-5KCT. The 6AK6 uses 10K for maximum power, but you can try it... it doesn't draw much current, so it may not saturate TOO badly...
Page generated in 0.018415927886963 seconds with 16 queries,
spending 0.00769854 doing MySQL queries and 0.01071739 doing PHP things.
Please support our sponsor.
