diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Soldering tubes directly to PCB? - Click HERE for Original Thread
thomsva
I´m scetching up a layout for a tube based preamp. I would like to use a low profile enclosure with the tubes inside. But if the tubes are standing up lots of vertical space is needed.
If the tubes are soldered directly to the pcb i could get away with 75mm internal enclosure height:
15mm space between bottom plate and pcb
2mm pcb thickness
50mm tube soldered directly to pcb
3mm space to vented enclosure cover
70mm total
Using a tube socket on the pcb would increase the total height by approximately 15mm, and I don't like that.
The obvious drawback is that changing tubes is a hassle. But is there anything else?
tubewade
Thomas,
Perhaps you could lay the valves on their sides rather than straight up. That would reduce required height by about 25mm.
Wade
kstagger
there were flying lead tubes produced that were made for just that type of use - for example
http://cgi.ebay.com/EF86-CV4086-GEC...ksid=p1638.m118
tube replacement is of course the biggest concern - AMC came out with an EL34 tube amp - model CVT 3030? - which had the EL34s soldered directly to the circuit board. Bit of a problem if you wanted to roll some tubes.
oshifis
I have done it in the past but I advise against it. The glass around the pin may easily get cranked due to the soldering heat. Result is air may leak in the tube. The crank may be invisible and the leak very minor.
As you mentioned tubes need to be replaced from time to time. A tube may become noisy or just sounding dull or distorting at any time.
If you want to reduce the height, mount the tubes in horizontal position. I used silicone rubber rings to hold them. Good ventilation is also important.
Tom Bavis
Use separate socket pins by Mill-Max in your PCB. Will add only 1-2 mm height over tubes alone. Digi-Key stocks these - look for .040" pin size.
These can be especially useful for tubes like 10 pin or 12 pin, where sockets are hard to find.
Nordic
http://www.diyaudio.com/forums/show...6110&highlight=
dhaen
If mounting horizontally, best consult the manufacturers data sheet. They sometimes recommend the orientation ie which pin uppermost.
Alastair E
2mm pcb thickness
70mm total
You could use Nuvistors.....
The socket and valve cant be much more than 30mm high total....:D
The Russian wire-ended Nuvistors could be soldered straight in or wires cut and sockets used, as I have done. They are MUCH better than the NOS American things for noise and Michrophonics. Great valves. Type 6C51N is a nice medium Mu triode, and will work well (In the right CCT) down to 12V.... :bigeyes:
David Davenport
Chek out the Tyco/AMP 5050865-3 discrete socket
Wavebourn
quote:
Also, a big heavy nut glued on a 6C51H (pronounced 6S51N) reduces microphonics dramatically.
poynton
Right-angle mount tube sockets
Angela.com
Andy
Geek
Hi Tom,
I just measured a few minature tube pins and they're 0.85mm, ~0.034" (my caliper is in metric, eh? :D ). Looking at my Digi-Key catalog, ED5013-ND which fits .032-.046" and a 3/32" drill hole look good.
What do you think?
Cheers!
Wavebourn
quote:
Originally posted by Geek
Hi Tom,
What do you think?
Cheers!
When I was a teenager sockets for GU-50 were hard to find so I used pins from military plugs.
Hi-Q
Another way that might gain you a bit of space is to hole cut the pcb to take the full width of the tube and have the socket mounted below using spacers. A sheet of thin insulating material glued to the chassis directly underneath the socket connections is recommended though in case the pcb is accidentally flexed downwards.
kuroguy
quote:
I've seen pornstars have this done to them.
Hi-Q
:) I dunno, you young lads :)
thomsva
Thank's for all the ideas! There are several options.
I also might forget about the pcb and do a point-to point arrangement. Then I could polt the sockets to the bottom plate using pcb-spacers. Would 10mm space between socket legs and chassis be enough for 250VDC? Or is even 5mm safe?
edit: this arrangement actually does not save any significant height compared to a pcb arrangement. But minimising the space to the bottom plate would help.
Or... i could mount them on their sides.
Wavebourn
May be like in my mic pre, to use a rear panel for a twin triode and an angle for an indicator?
Nordic
Looks like a gun! :eek:
Page generated in 0.044946908950806 seconds with 17 queries,
spending 0.00752330 doing MySQL queries and 0.03742361 doing PHP things.
