| gainphile |
Hi guys, for the past 3 months since rediscovering the hobby I keep going to bed reaaally late, 1 am in average which is about 4-5hrs of listening everyday.
This is not including 'listening while tinkering' which saw me few sleepless night :D
So let us know how long/often you listen to music ? ... :yes: |
| exurbia |
goes on at 5-15 when i get home :) and goes off when i go to bed at 10-1015 :D
our tv is in the same room and only gets turned on once a week for top gear and drawn together.
music is around us constantly on weekends. |
| vasyachkin |
| whenever my neighbors are at work |
| rabbitz |
| You actually listen? ;) I'll have to try that. :D |
| SY |
Every moment that I'm home and my 7 year old isn't.
("Daddy, that's too loud!") |
| AndrewT |
| all the time I'm at home, probably more than 14hrs a day. |
| adason |
| 3-4 hour during working days, all the time during weekend when I am home |
| t-head |
12 hrs a day minimum...24/7 max when burning in ears,,,
Have SYs' problem when daughter visits...'poppi, thats toooo loud! :xeye:
t |
| vasyachkin |
instead of listening loud i equalize the loudness curve
i keep the response flat from about 500hz to 5khz then i boost it by about 3db towards 16khz and i boost it by 20 decibels or so towards 30hz
the key is to avoid peaks at any bass frequencies and calibrate response by ear using test tone generator.
if you do it right you will have powerful satisfying sound without any ringing in the ears
naturally this approach has its own problems ... actually im not sure if it would help any of you because when bass is equalized this way it goes right through sheetrock walls ... but at least within the same room it can be satisfying without being offensively loud |
| myglaren |
Varies greatly, can be between 5 and 9 hours at a stretch but it isn't often I get that much uninterrupted time.
Fell off a lot as I have the music system in the sitting room, where the TV is and my computer in my bedroom - I didn't want a PC whirring away in the sitting room.
The irony is that the PC is silent but my kids tend to evict me from the sitting room so they can watch the telly.
And the telly has now become a pivotal point.
Other than the fact that I bought a laptop so I could sit in the sitting room, listen to the HiFi and plottrar on the computer, the telly died - or at least was killed to death by one of my grandchildren.
So today I bought a 50" LG plasma and a HD DVD, so I can watch and listen to my Mylene Farmer and Loreena McKennit music DVDs, and the Ting Ting one if and when it arrives from Japan.
They wanted to sell me a 7.1 Home Theatre noisemaking kit and didn't understand the concept of putting it through a decent amp and leaving it as 2.0 stereo. |
| larc99 |
A lot...I sleep with mine on with the music from my sound server/computer/life set on random (its kinda like listening to the radio but without commercials and listening to the same set of songs on loop). I also use my system for gaming if that counts for about an hour a day.
How much time I listen also depends on what you classifiy as music...My parents and sister don't think bands like Primus and such are music... |
| R B Customs |
I wish I had the chance to listen to mine more to be honest, I listen to it every night for a few hours plus when I go to bed.
I would say 3-4 hours a day.
when he neighbours go out though ... :D |
| jackinnj |
My GFP-565 DH220 (or LM4702 LatFET) and KEF system runs from about 7 in the morning to 8 at night (when the XYL gets home from the research lab). Mostly vinyl, WBGO, WNYC or WQXR -- the vinyl keeps me sane as I am forced to walk away from the bench when the record is at an end. WBGO is very easy to listen to during the day, or if I am commuting into NYC.
I have one Linn system on our little library -- since I acquired a TX9500 tuner I listen to this in the evening when I catch up on the papers. I also have a laptop in the library to see what's going on on various papers, or to check the upcoming programs on TCM !
...and then at the end of the day, Laura Ingraham is on WABC(delayed)...so I get my fill of talk-radio. |
| JDDCo |
I have a 8, 10, 12 year olds. & 4000s cd
My kids tell me that the music from the 70's
is better than today's and yes I listen Alot
4- 7 hours a day. |
| technofreak |
I wake up, first thing is to power it up.
I go to sleep, last thing is to switch it off... Sometimes:clown: |
| RM529 |
| Sunday mornings for 4 hours for sure. Other times as available. |
| eStatic |
| I don't listen at all if I am working on a composition, otherwise a hour or two a day. But I listen with my eyes closed (even at concerts) and can do nothing else at the same time. |
| mpmarino |
| quote: | Originally posted by SY
... me too. I have to add my wife to that though. The problem is that they are always home when I am :rolleyes:
This translates to about 30 seconds listening per month. I only need 12 LPs for the rest of my days on earth ;) |
| TheMG |
Not very often at all, maybe an hour every few days.
Why?
-need better sound card
-need better amp
-need better speakers
-need more FLAC music!
In the state my system is in right now, it's only slightly better than your run-of-the-mill "mini system". Can't listen to it for long until my ears start to bleed. Most of that can be attributed to MP3 compression. Finding lossless audio is not easy (if you know any good source by all means send me a message!) and buying dozens or even hundreds of CDs is out of the question, I don't have thousands to spend on that, not to mention there's a lot of stuff you can't even find at the music store.
I'm in the process of building a better amp (2x UCD400). So that'll be one step forward. After that comes the sound card, and then speakers a year or two down the road. |
| FastEddy |
I listen to my system every day, at least an hour per day. Until the wife comes home from work and wants it down or off. :D
I turn it way up when its just me ... to a point about ~3 to 6 db down from clipping.
JDDco: " ... My kids tell me that the music from the 70's is better ..."
My wife tells me that the kids at her job all tell her that the (redone) music from the '70's and late '60's is what they buy and listen to as well.
I buy nothing but DVD's [video and audio] of the old folks from the '60's, etc. = electric blues,R & B, R & R ... [ "... the audio resolution of a DVD-Audio disc can be substantially higher than a standard red book CD audio." ] :hot: |
| Beowulf57 |
| 2 to 3 hours per day does just fine for me...sometimes background, sometimes critical listening. |
| Richard Ellis |
Power up the system when I come downstairs in the morning, off when we go to bed.
The same as most housholds "Daddy thats' too loud!"
This very moment my son is running "Jet Moto" thru the system, some realistic? sounds... (sound FX) He doesn't mind high volume for his sound Fxs'???
Sony Trinitron 32"
Apex VCR/DVD
Yamaha CX-800...pre
Harmon Kardon TU911...tuner
Carver TFM-15CB...amp
42" DIY MTM Tower spkrs
...........OK...hes' off JM, time to return to my Enya I had playing before he commanderd the system.............
_________________________________________Rick............ |
| JDDCo |
| A six pack and Dave Matthews live in central park DVD always makes the neighbors made! |
| jackinnj |
| quote: | Originally posted by JDDCo
A teacher in NYC got fired for telling one of the kids "your a six pack without the thingy which holds the cans together." |
