diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
First chip amp - Looking for suggestions - Click HERE for Original Thread
peter_m
Is there a preferred chip for a solid 30 to 60 watt / channel amp for an 8 ohms load? First time project so it should be a "simpler" design using inexpensive chips so I can burn and learn...
Also is a 100 or 150 watt sub amplifier worth the time and effort?
Peter
Nordic
LM3875.. with 25VAC transformer , say 200 to 300VA, only need to use 5 of its pins.. can cut the rest off.. with parts soldered point to point....
google Nuuk's site Decibel Dungeon...
Erm... I would say its probably less hassle for the money to get a small plate amp for the Bass.
gmilitano
Here are some other point to point gainclones:
http://diyaudioprojects.com/Chip/P2PLM3875/index.htm
http://dogbreath.de/Chipamps/GainCa...inCardCopy.html
paulb
If you'd prefer a PCB take a look at www.chipamp.com. LM3886 is very similar to LM3875.
jduffy
Nice Links man. I used Nuuk's site and took what I could get from the forum. I got mine up and running first try with no problems to speak of.
Page generated in 0.02222204208374 seconds with 17 queries,
spending 0.00707984 doing MySQL queries and 0.01514220 doing PHP things.
