diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Quick FET question - Click HERE for Original Thread
spooney
Is an STP55NF06 a different or perhaps newer version of the STP55N06? Will it work as a replacement?
jol50
It does look a little more beefy and close, but I can't say for sure. Mouser has both and does not cross reference them, but does refer to a NDP6060L for the NF06 and that is the sheet I looked at compared to the N06. Most of the specs look good. I did a Sony that was more off than that and it worked fine, no way was I paying 15 for a TO-220. However most people say the originals should work fine if the amp has no other issues, for what that is worth.
Perry Babin
If this is for a power supply, they should be interchangeable. The NF version appears to be the replacement.
Page generated in 0.065658092498779 seconds with 16 queries,
spending 0.05450010 doing MySQL queries and 0.01115799 doing PHP things.
