diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
BFD, DEQ or DCX - Click HERE for Original Thread
Fore
I'm finally getting started in this whole new business to me, sub EQ'ing. I"ve got the wiring/cable thing all worked out, but from my research, most guys are using BFDs. But from what I've gathered here, alot of people are using the DEQ instead for it's 'shelf filters' allowing a flatter fr <10hz. How important is this? Is that the right decision??...it's about $150-200 more than the BFD.
I plan on using it to eq one sub now, another possibly later, and plan to have two memorized EQ parameters, one for HT, and another for strict two channel music. If possible, I could use a 'pretty good quality' high pass filter for my mains for use with music.
Any help or suggestions are really appreciated!!
Thanks,
Fore
MaVo
you could use a personal computer equipped with a good soudcard like RME for this. thats also more diy :)
Fore
I'm going to use my vista computer, with a soundblaster live ext. soundcard, mic, preamp, and mixer along with a one of the Behringer processors listed above.
I should've seperated the DCX2496 crossover and the quality for a highend 2 ch. music system. I did a bad job there.
If someone has experience with this unit it'd be great to here.
The other question is, is the DEQ with it's shelfing filters the better choice for my situation? Say over the BFD? Just a bit confused over which proc. is the best for me.
chops
I'm kind of in the same situation. I'm trying to figure out which would be better for tuning my sub as well.
This one...
http://www.partsexpress.com/pe/show...tnumber=248-656
Or this one...
http://www.partsexpress.com/pe/show...tnumber=248-657
There's a $50 difference, but is it really needed for tuning a sub from 50Hz on down?
Any ideas guys?!
Fore
Anyone else willing to join in which unit I should get...bfd or deq??
chops
quote:
Apparently not.
It's funny, there's like a million and one members on here using these units, but when someone asks which would be better to buy, no one cares to respond. Go figure.
RobWells
I've got/had all 3 units. Peronally prefer using the deq than the bfd. Results are good regardless off which unit you buy. Maybe the dcx could be a better buy if you intend to build a set of mains later on.
Rob.
Page generated in 0.024631977081299 seconds with 17 queries,
spending 0.00809813 doing MySQL queries and 0.01653385 doing PHP things.
