| lordvader |
Hey all.
I'm planning on building an F3 power amp, and am considering going dual mono (why not !!!).
Anyways, I know that when your transformer requirements are beyond 300VA, a softstart is recommended, but is that per transformer, or overall ?
I'm considering 2 250VA transformers (with 66000uF after each of them). In this scenario, since the inrush current is split over two transformers, I'm not sure if the softstart is required. |
| Zen Mod |
| quote: | Originally posted by lordvader
Hey all.
it's not just VA rating of xformer , but also No. of kilouF you have after ;
in any case - use CL60 as Papa does and enjoy |
| Magura |
| quote: | Originally posted by Zen Mod
True, but the limit is somewhat more than 500VA and 66.000uF.
I start up my 1000VA and 200.000uF PSU's without softstart, with no problems.
Magura :) |
| Zen Mod |
| quote: | Originally posted by Magura
Magura :) |
from which line ?
what circuit brakers/fuses you have on that line .......... ?
:clown: |
| Magura |
from which line ?
:clown: |
230V 13A
Magura :) |
| Zen Mod |
230V 13A
Magura :) |
fast ( automatic) ones or slow ( ceramic, melting) ones? |
| Magura |
Slow blow 13A ceramic fuses.
Magura :) |
| Zen Mod |
Magura :) |
and what's fuse in front of that sissy donut? |
| Magura |
10A slow blow.
Magura :) |
| Zen Mod |
10A slow blow.
Magura :) |
:rofl:
that's why you don't need soft start .......
you can also put there smith nail instead
:clown: |
| Magura |
:rofl:
:clown: |
Sure, but the 10A fuses were cheaper than nails of the same size :D
Well, the fuse is there to stop things from turning real bad in case the trafo goes south. On the other side of the PSU, the fets will blow, take out the source resistors, and put an end to any further events.
Magura :)
EDIT: Just checked, the fuse is 8A slow blow, not that it makes any particular difference. |
| OliverD |
A softstart circuit not only prevents the fuses from blowing, it is also going easier on the expensive caps... Although I have no proof, I would bet that it lengthens the useful live of the PSU components.
A softstart circuit can be as simple as a thermistor, or, if you don't like the idea, a power resistor and relay (driven from the secondary side of the transformer) shorting it some ms later. |
| Magura |
| quote: | Originally posted by OliverD
True, but overkill does the same for the life expectancy :D
Magura :) |
| Eva |
Magura :) |
Ahh this is stone age... Try modern automatic circuit breakers.
Doesn't the lights dimm and the computers reset when hard starting this 200.000uF power supply? I bet that if you move the amplifier some day to a place with a slightly weak mains line, this is going to happen.
A smart amplifier intended to work everywhere should include soft start. |
| Magura |
| quote: | Originally posted by Eva
Yeah, you're right as far as the stoneage fuses, but they happened to be there when I bought the house.
In Denmark we have very nice mains, hardly any unwanted stuff and hardly any fluctation, compared to most other countries I know of. So as long as I stay here in DK, this should cause no problems.
Magura :) |
| OliverD |
Reminds me of the days when I took my DIY PA system to parties... At one place the circuit breaker would consistently trip when powering on the last of the six amplifiers. We had to "simulate" soft start by manually resetting the breaker 10 or 20 times within some seconds - until the capacitors had enough charge to not trip it again.
Lesson learned: Made a small soft-start PCB, bought twenty sets of relays and power resistors and installed one in every amp I came across ;) |
| AndrewT |
your 250VA operating on 220/230Vac mains will run all day at full power from a 1A fuse.
But as with all transformers and motors it needs a much larger, or slower, fuse to start up. It is usual to fit a fuse rating of about three times the full power current rating.
This would require a 3A fuse for each transformer.
If you fit a soft start you can reduce the fuse back down to or maybe even less than the full power rating and still operate the amplifier without nuisance blowing of the mains fuse.
Remember, the fuse is there to stop the downstream cables and equipment setting the house on fire if a serious fault causes excessive heating.
A close rated fuse provides better/safer protection than taking the easy (big fuse) route. |
| peranders |
| Magura, I'll guess you have a robust mains switch also? You must have inrush currents of 100 A or more. |
| Magura |
| quote: | Originally posted by peranders
Reality is something like 30A inrush, so no particular issues there.
I though have wondered in the past if such could be a problem, so I opened a mains switch that had been in service for a few month. No harm what so ever to the contacts.
Magura :) |
| peranders |
| If you have toroid transformers you should have the top voltage divided by the primary winding resistance which is 300/3 = 100 A at least |
| Magura |
For like 1 or 2 cycles, yes, but after that, just like 30A and even that decreases rapidly.
Magura :) |
| AndrewT |
For like 1 or 2 cycles, yes, but after that, just like 30A and even that decreases rapidly. | Soft start is the term applied by most DIYers to the time/current required to get the toroid transformer working.
Slow charging may be an appropriate term to apply to controlling the current through the rectifiers.
Magura,
you are confusing the issue (and probably Lordvader) by referring to your peak charging current of the smoothing capacitors, but calling it soft start. |
| lordvader |
Well the discussion has been very interesting thus far !
I'm definitely going to put some form of soft start. Still not 100% whether to use a thermistor per transformer, or a softstart per transformer.
I'm about to order 2 300VA transformers. However, these only have a single 240V primary. Where would the best place for the thermistor be in this scenario ? The only options would be to put the thermisor on the hot leg (in series with the fuse), or on the return leg. |
| AndrewT |
A soft start can be either a Power Thermistor or a Power Resistor in the primary feed. The option is whether you decide to add a delayed bypass (500mS) to the Power Thermistor version. The Resistor version MUST have a delayed bypass (300mS).
I would recommend that the "resistance" be placed in the Live feed, to avoid the scenario of the soft start going open circuit and leaving the whole primary side live even though the amp appears dead.
If you have a large smoothing capacitance, you can also consider adding a slow charge circuit into the secondary before the capacitance. A Power Thermistor again with optional delayed bypass (3seconds) works well.
I recommend that each transformer has it's own T1.25A fuse and that the amplifier has an input fuse rated to match the downstream cables.
Do you use plug top fuses in Australia? This should be rated for the input flex current limit. |
| lordvader |
| quote: | Originally posted by AndrewT
Thanks for the reply, but that sentance kinda went over me ...
I do plan to give each transformer a 1.25A fuse, but what do you mean by input fuse to match downstream cable ? Aren't the 1.25A fuses the "input" fuses ?
And what are these plug top fuses ? Do they differ from the standard 3ag (i think that's right) type fuses ? |
| AudioFreak |
lordvader,
Just to straighten a couple of things out for you.
1. No we do not use plug top fuses, so don't worry about that.
2. There should be a fuse before the transformer and then each of the rails should be fused. The transformer fuse should be rated according to the safe operating limits of the transformer. The rail fuses should be appropriate to the amount of current draw you expect on each rail. |
| AndrewT |
In the UK, we are required to protect ourselves from our own folly.
Belt and braces, that are not universal around the world.
The general rule is that a fuse rating must be smaller than the smallest unfused cable that is suppled by the fuse.
At the distribution board there may be a 30A fuse or breaker. That demands that the down stream cable rating must be greater than 30A. In domestic, we use a twin and earth ring for each power circuit, each half of the ring is usually >=2.5sqmm with a current rating of 17A to 20A depending on cable environment. Two of these comply with the >30A breaker.
At the socket outlet in the wall, we fit plug top fuses between 1A and 13A. This allows the equipment cable to be smaller than the main distribution cables around the house. If we fit a 3A fuse in the plug top that allows an equipment cable of 1sqmm (~6A) to be used to feed the appliance.
Inside the appliance the manufacturer usually fits a further fuse (for the countries that don't have plug top fuses) This is usually fitted very soon after the input cable enters the appliance and can be incorporated in the IEC connector socket.
You have two transformers. If you fuse each @ T1.25A then these could draw around 2.5A from the mains and not rupture the input fuse in normal operation.
The input fuse (IEC?) would have to be >=3A to allow operation for all normal circumstances.
A 300VA will probably need about 50r to 70r in the primary feed to avoid nuisance trpping on start up. You may have to experiment with the resistor values. I use a bank of 10r 5W radial resistors for this and add as many as I need to give reliable start up.
Does that make sense?
Following up on rail fuse rating.
I find that a rail fuse of about half the peak current into your minimum resistive loading allows reliable operation and even sustained full power testing. i.e. F3A allows 6Apk to a resistive load. That is equivalent to 48Vpk into 8r0 = 144W into 8r0. |
| lordvader |
And then the world made sense :)
Thanks guys ! |
