diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Philips cdm 9 pro replace? - Click HERE for Original Thread
serraniruben
Hi all,
I read a topic reffered to the philips cdm 9 pro mechanics in the forum http://www.diyaudio.com/forums/show...25&pagenumber=1
and need contact with ohynot (because they have units for sale), anyone have the mail, I can read the link.
Others users have spare philips cdm 9 pro mechanics links or where can find one.
Thanks for your time!
Rubén
MJW
Well I think you are going to struggle with this transport I'm afraid.
It's very rare. Like looking for a Studer/Philips CDM3.
On a bright note however I'm sure I recall the plain CDM9 as being interchangeable with the PRO mech, so provided it's just the lazer diode that has expired you can just swap them over.
If you go to Ebay and do a search for CDM9 you should find a number of sellers of brand new mech's. Around £30-40 give or take a few escudos.
Actually as I'm not 100% certain about the interchangeability get in touch with Jean-paul, a member here.
He knows lots of definitive information about this stuff and I think he actually has a number of stashes of different transport mechanisms, aside from loads of other stuff no doubt. Ha ha....
He will know. Best of luck. Matt.
serraniruben
Ok Matt,
Thanks for your info!
Rubén
atarashi
Hi Rubén,
which Part of the CDM9Pro do you need?
brgds
Michael
serraniruben
I need the motor.
Thanks!
Rubén
serraniruben
Hiall,
Anyone know if the motor in the CDM 4 is the same that the CDM 9 (hall brushless)
Thanks!
Rubén
atarashi
Hi Rubén,
well, Schnepel in Germany still has a few of these:
http://www.ersatzteil.justone-schne..._44_cdm944.html
not cheap, but so are the CDM9Pro based drives ;-)
brgds
Michael
serraniruben
Hi Michael,
In your link the mechanics is the 9/44 , I need the pro version, but send a mail to know if still have in stock this mechanics
Thanks!
Rubén
atarashi
Hi Rubén,
well, they state on their site, that they are compatible...
hope it works out fine! (keep your cdm9pro alive!)
brgds
Michael
dtektoni
Hi All,
Is there anybody know where in Philips CD players CDM9 PRO is used? I'm looking for brushless motor schematics.
Regards Dmitry
stephensank
All I can recall for sure, off hand, is that the CDM-9Pro w/the brushless motor was used in the Krell KPS-20i. If you contact Krell, they may at least be willing to send you a schematic of the motor/servo section, though they pretty definitely won't give or sell a schem of the whole KPS.
kevinkr
It was also used in Theta Data, a couple of the more expensive Rotels, and the PS Audio Lambda Drive.
The motor used in the 9/44 IIRC has brushes and will not interchange with the hall effect commutated motor in the pro mechanism.
I used to have a Lambda Drive and could not get the parts nor information required to repair it when it started to fail.
Be very careful buying "NIB/NOS" lasers on eBay - I paid over $100 for a 9/44 for the laser assembly that was supposedly new, and the laser was in fact worse than the original.
The control protocols used with the pro are not compatible with the latest mechanisms from Philips so that is no way out either.
Most of the mechanisms used on an OEM basis came from Daisy which has the worst customer support policy I've encountered. (They never even replied to my email request for information, but the spam I received from them for several years sort of indicated that they got that email.)
Requests for schematics will be met with silence, because unfortunately I don't have ANY at this time. I have lately been deluged with requests for schematics based on posts I made 2 1/2 yrs ago on another thread.
I dumped my PS Audio gear long ago because I could not get spare parts to maintain them. It was quite unfortunate as they performed well and sounded great, but age is the enemy of electronics and they were wearing out. (The Lambda was dead when I sold it.)
While I'm on my rant I will NEVER buy an expensive player with a Philips mechanism in it again. The mechanism was discontinued after just a couple of years and apparently Philips made no provisions for spare parts. OEM cost of these mechanisms was several hundred dollars so it is hard to understand.
dtektoni
The idea is to find some brushless motor in order to change one in cdm9pro. I don't think that philips was invent something special.
It usualy contains 3 hall sensors and 3-phase motor, plus Vcc and Vee that give 11 outputs
For example cdm12.5 or 12.6 have brushless motors .
They also equipped with 11way flexible cable.
I have broken rotel RCD930 and opened cdm9pro motor, so it is possible to draw out schematic from pcb, but much easier to buy schematics.
Sorry, I didn't understand exactly what do you mean?
Will you explain me please.
Dmitry
kevinkr
quote:
Originally posted by dtektoni
<snip>
Dmitry [/B]
The new Philips mechanisms use a different command set than the old ones did and they are not compatible so bodging a current cdm2pro into one of these older players is not feasible.
konaneil
I hate to be discouraging but should you find a replacement for the motor, the laser will likely die soon after. These usually burn out before the motor and from much experience, NOS stock replacements are usually useless. They degrade just sitting on the shelf.
Really too bad. These could allow for really good sound when the rest of the product was done properly.
While second hand info: a friend who had one in a transport with a fading laser that was playing less and less of her discs, as a stopgap measure, replaced it with an Oppo for about $150 and was surprised that it made her DAC sound significantly better.
eledora
the CDM9 pro new one is hardly to find now, the price is up to 250 euro and without machine(the one with machine is about 350 euro/pc)
and the second hand can be find every where, the owner only sale by test, how can it work is belong to your fortune
Page generated in 0.046667098999023 seconds with 17 queries,
spending 0.01047373 doing MySQL queries and 0.03619337 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
