diyAudio.com diyAudio Forums Archive > Top > Source > Digital
AD1865 the best DAC - Click HERE for Original Thread
audiodesign
After some test with No oversampling DAC chip I think that the AD1865 is the best.
If compared to the new technology DAC chips like AD1955 and CS4397 since to be more natural.
The old TDA have a too close sound and with these some particulars are lost.
The preview of my article is here
http://www.audiodesignguide.com/DacNoOverSampling/
But where I can get some AD1865 chips to create a kit ?
Someone have tested the AD1861 or the AD1851 with th esame technology ?
Bernhard
Did you try PCM56 ? Same as AD1856 = 16 bit version of AD1861.
Best IMHO.
Every kind of TDA sucks, right.
Do you use an analog filter ?
I tried everything from unfiltered over transformer filter to active & passive brickwall and passive brickwall sounds best.
Your THD numbers seem to be a little bit.high.
Why only show spectrum to -80dB ?
QSerraTico_Tico
quote:
Originally posted by Bernhard
...........and passive brickwall sounds best.
Any schematic?
Do you use a digital filter?
Bernhard
quote:
Originally posted by QSerraTico_Tico
digital filter?
:eek:
audiodesign
No digital filter
I/V converter made with a Caddock MK132
No analog filter, in the final version a LL7903 wil be used to increase the output voltage and tii create a natural filter
Cauhtemoc
You should consider the AD1862 as well, it is the bigger brother of the AD1865.
audiodesign
I cannot find a shop to by the AD1861 or Ad1862
A question:
- also the new product dac like ad1955 could be used without digital filter and no oversampling ?
QSerraTico_Tico
No digital filter
You will have birdies all over the place... and intermodulation poducts. What is a "natural" filter?
My question was addressed at Bernard though.
QSerraTico_Tico
A question:
Group buy for AD1862 on this forum!
AD1861 I still have at least 4 for sale.
QSerraTico_Tico
:eek:
Do I take that "eek" for a no?
audiodesign
price for 2 x ad1861 ?
I cannot find the group buy the ad1862
xaudiox
I cannot find the group buy the ad1862 [/B]
check on the "other" forum.
http://www.diyhifi.org/forums/viewt...bdc673&start=30
QSerraTico_Tico
http://www.diyaudio.com/forums/show...threadid=111064
QSerraTico_Tico
Sorry I have to correct myself; I have only for sale the 16-bit AD1851.
(The AD1861 is an 18-bit DAC)
How would you use an 18-bit or 20-bit DAC NON-OS anyway? Not using the MSBs will make it sound very faint.
whatsup
Folks, the excitement is building and it is only a matter of time before the worlds first 1-bit NOS DAC is announced right here in this forum!
Bernhard
Yes, a no.
A'af
I have some AD1865N and AD1865N-K to sale, -K is for military grade, pls mail me further, thanks.
all the best,
a'af
rfbrw
quote:
Originally posted by whatsup
.....it is only a matter of time before the worlds first 1-bit NOS DAC is announced right here in this forum!
It already has. Two years ago.
QSerraTico_Tico
quote:
Originally posted by A'af
I have some AD1865N and AD1865N-K to sale......................
a'af
Me too!
rfbrw
Me too!
A crash in the AD1865 market ? A revaluation of the TDA1541A can't possibly be far behind.
QSerraTico_Tico
quote:
:D
:clown:
minivan
i found this on the chinese website, i am on the hunt for a dac
is this dac any good? retail for $2980 RMB (yuan) before shipping
● Standard input: Coaxial SPDIF, Optional input: USB-SPDIF,AES/EBU
●Input sample rate: 44.1, 48, kHz/16/18BIT Auto detection
● Signal to Noise ratio:>110db
● Dynamic range:105dB
● Total Harmonic Distortion:1KHZ%0.005
● Rated Power: 2VPP
● Frequency Response: 20-20kHz-0.2db
● Total Power >30W
●Dimensions: 430*270*65mm
●Weight: 5.2kg
robot
Looks nice for 400$, which is converted price, strong built, with a switching button which looks like famous "lounch missile" button in B action movies. Actor have to cut one of wires to stay alive, red or black, or yulong s gonna blow....:dead:
Number 16 Fs actually worries me, anyway, I think that guys from Romania, made better dac...rockna
But, I agree with audiodesign, ad 1865K is awesome, natural, punchy and had a plenty of detail. Worth every cent.
tubee
Anyone tried that AD1865 Rockna dac? And compared to the 24 bit upsampler from Rockna?
fatmarley
Has anyone heard the WM8741 from Wolfson Electronics?
128dB SNR in mono
audiodesign
8740 no 8741
see
http://www.audiodesignguide.com/DAC_final/DacFinal.html
fatmarley
Wow! great review.
I use a budget Cambridge Audio 640v2 (Mono WM8740's) and it's made me think the TDA1541A is getting a bit dated.
I replaced the electolytic coupling capacitors with films, decoupled the DACs with Oscons, replaced the 7805 that feeds the clock with a Pinkfish flea CLICK HERE and
used a LM1086/VBE to feed the 5v analogue supply to the DAC.
I'm really pleased with the results and i havn't touched the 78xx/79xx +/-15v supply to the opamps (NE5532)....Yet!
I'm going to build a basic LM1086/337 supply and when thats fitted, i will experiment with the opamps.
tubee
Clock upgrade in the Cambridge?
fatmarley
I didnt upgrade the clock because it looks like a good one. I replaced the 7805 fixed regulator with a pink flea and built a seperate PSU for it (Transformer, bridge rectifier and cap)
Spartacus
Hope to try the WM8741 in the next couple of weeks.
Dan
rfbrw
quote:
Dan
Where did you get it ? The website cites an eight week lead time.
Spartacus
"Engineering samples" from a distributor. They are an older revision, but apparantly have the same perfromance.
fatmarley
Dan
Hhmmm - Cheltenham.
Would love to hear the WM8741 ;)
Spartacus
Matt, I'm sure that can be arranged!
Dan
fatmarley
Cool!
My email address is: mattfarley at msn dot com
rubydac
I used digital schematic from Audio Note DAC Kit 1.1
AD1865N-K NO OS, 12AU7 output and EZ80 rectifier.
Walt jung super regulator + spectral dmc-20 for +/- 5V analog supply.
Single board completed.
Rubydac
QSerraTico_Tico
What is Spectral DMC-20? Any schematic?
ak_47_boy
TDA1543 is one of the best. People want 24bit now though because of sacd.
QSerraTico_Tico
quote:
It's also about implementation: type of IV-conversion, low-pass filtering, output buffer....
Bernhard
1543 distorts like hell, no matter how proper is implementation.
QSerraTico_Tico
There is no causal relationship between distortion and sound quality.
Bernhard
:hypno2: :rofl: :hypno2: :rofl: :hypno2: :rofl: :hypno2: :rofl: :hypno2:
rfbrw
And there is no correlation between a windscreen covered in mud and a lack of visibility.
QSerraTico_Tico
Yeah if you start mud slinging.....
zener_diode
WOW! That Youlong is pretty old school.
I built a couple of DACs with Analog Devices' converters before...
nice, but I like the Burr Brown chips better.
audiodesign
Rubydac sell the pcb ?
robot
I don t see anything revolutionary in rubydac s design, he simply switched audio note version of sulzer with jung regulators, tube output with tube rectification. Identical approach to a glue logic, as old romans used to say: nihil nove sub sole.
I tried lundahl 1636 passive, fets, but sole tungsol 5687 kick *** to all of them. :dead:
tubee
nihil nove sub sole: Niets nieuws onder de zon
We use that phraze too still.
audiodesign
I have tested today a pair of LL7903 to increase the output level but the result was a bad sound.
The AD1865 since to be perfect with a caddock 200-250 ohm resistor and nothing else
I will try soon a ECC82/12AU7 stage after this passive I/V conv
robot
At first to explain my dac, I used dsavit s boards ad1865/5687 with ccs, but I used power supplies like audio note does it for digital board, and I used 220R audio note tantalum resistor on I/V conversion. Putting LL1636 on the output looked nice with some bass restriction, and lack of punchy - solid state kick. Sound with lundahl is very neutral across the whole audio spectrum but I feel that I miss some "action". Experiments with scope would probably solve problem of matching impedances which is crucial for the best ad output. Putting 5687 on the output of the dac changed sound and made it crispy, punchy with lot of detail, witihout any trace of treble harshness. Whole dac is in the inox case, with big power supply and 10H choke, clrcrcrcr...
(nothing new under the sun..:)))
I presume that would be interesting to see the values of audio note dac 5 interstage transformer (I think around 680R in primary), which replaces I/V resistor.
Bernhard
did you terminate the secondary ?
if not, there will be ringing and it will sound ugly...
play a cd wth a square wave and watch it with a scope.
adjust with a 50kohm pot across sec. until ringing disappears.
Bernhard
quote:
personally I am afraid tube output stages will always add some kind of coloration to the sound (?)
Bernhard
What are the best transformers ?
Lundahl, Malotki, Western Electric, UTC, Tango ?, what else ???
robot
Any active component adds something to sound, that s obvious, but if I have to choose I prefer chain which consists of a few parts than a bunch of transistors, opamps and other stuff.... I wrote on other place rather poetically, that a dac with solid state output is electronic component, and with tube output is a musical instrument.
:angel:
For example, I m using for sound comparing, and testings my friend s rather old combination of meridian 200/203 which uses very good SAA r2r dac, but it has infamous ne5534 opamps behind famous meridian digital stuff, and I think with a decent tube output would make this oldboy a killer dac.
Anyway I think that combination with a transformer on I/V than tube is very promissing in this case.
Considering best transformer, aren t Lundahls now in Jeff Rowland s gear?
Bernhard
Recently I found a link to a website where big tubes are used for DAC outputstage but lost it...
Anybody knows the link ?
audiodesign
My test untin now are test:
1) only a 320ohm Caddock MK132 resistor connected to DACT 10k and to the amplifier
2) a 320ohm Caddock MK132 connected to LL7903 1:4 and to the DACT 50k and after to the amplifer
3) no resistor, connected to LL7903 1:8 and to the DACT 50k and after to the amplifer
case 1 play very good
case 2 play bad
case 3 play better but I not sure better than case 1
case 3 = audionote choice
robot
There was a discussion a few years ago about this conception of I/V conversion on this forum, witihout any useful conclusion. Its obvious that audio note uses some transformer with silver wire behind dac very expensive indeed, but unknown specifications, so copying this witihout usage of their transformer is not effective, and probbably wasting time and money.
We all know about thorsten s try to copy an dac 4 signature, his adagio . It s obvious that he used I/V resistor, and some filtering before cf e182cc. Not an easy task I belive. I think the main difference between using transformer and tube output is lack of bass in first case, so combining those two approaches probably solves that problem.
Page generated in 0.10998392105103 seconds with 17 queries,
spending 0.00779986 doing MySQL queries and 0.10218406 doing PHP things.
Copyright ©1999-2009 diyAudio.com
