| Killjoy99 |
Maybe i'm just not "in the know", but I just aquired some 220uf 35V Elna Cerafine Electrolytics and was surprised to see that they had a black wrap around them instead of the standard red. I've attached a picture or two so you can see what I mean.
I've searched and searched and can't find a single picture of another black Cerafine other than the power supply version with the "For Audio" written on them.
| RKH |
If you look on e-bay, you will find sellers of the 'old style' red cerafines and the 'new production' black cerarfines. I've just starting seeing these pop up in e-bay, but no where else.
Hope that helps.
RKH |
| Killjoy99 |
| That helps alot. I've had just never seen the black versions and was making sure i didn't have some fakes. Thanks for the info, now its time to put them on my Mini-Aleph |
| RKH |
You're welcome... that sounds like a great use for those caps.
Good luck.
Ryan |
| emilg1955 |
| The balck cerafines are the new lead free type in production from about June 06, 0626 and later date codes. |
