diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Tandberg Solvsuper - Click HERE for Original Thread
vegard
Hi, you guys are great.
I have a Tandberg Solvsuper reciever from about 25 years ago, and as far as I have heard, they are are supposed to be quite good. It is in nice conditon, it can power two pairs of speakers and it has tape and phono in. Does anyone know if this unit is good? Are there any updates or such that I can do to it?
thanks,
Vegard
Netlist
If you really want to get nostalgic about Tandberg, try this link:
http://nrhf.no/nrhf-eng.html
Personally I have an old Tandberg cassette deck (TCD330).
It is very well build, like most of the Tandberg machine I saw in the past years.
What is the type of receiver you have?
/Hugo
halojoy
thanks,
Vegard
What version of Tandberg Solvsuper is it.
I searched the net, Solvsuper 1 came 1937-38.
I found numbers upto Solvsuper 12C on the net.
I guess the latest models used transistors.
At "Norwegian Historical Radio Society"
http://www.nrhf.no/nrhf-eng.html
you will find pictures of most Solvsuper models 1-12C
http://www.nrhf.no/nrhf-TR.html
Here is ´some pictures of a real oldie.
http://www.sparkbench.com/tandbergalbum.html
The picture below shows the first Tandberg Solvsuper 1
/halo
halojoy
Solvsuper 12 came around 1977
AM og Stereo FM receiver med 2 x 12W (FTC).
Solvsuper 12C had inbuilt cassett recorder, top-loaded,
on picture below.
vegard
Hi:
The history of this reciever: My dad purchased this during his college years in Norway (I am norwegian). He has a pair of speakers with it that have 8" (I think) drivers pointed up and four tweeterspointing in from each corner. The speakers are garbage... the tweeters are cracked, and the woofer dustcap is crushed. I might restore these at a later time...
Anyway, back to the reciever: It is a Solvsuper 12, without the built in cassete.
Here's what I want to do with it:
I would like to make it run off 120 v as opposed to 220.
I will build a separate selector box for attatching more inputs
And Id like to change the speaker connectors (the speaker cable requires little plugs that have one round pin and one flat pin) I would probably like to add banana jacks.
And if I can change/add components and get better sound I might want to try it. by the way, anybody else have one?
http://www.nrhf.no/TR-SS-12.html
Thanks,
Vegard
vegard
To make it run off of 120 volt, I assume I just change the transformer. Is this an area where I can upgrade?
Vegard
Gunderz
Maybe I could help you with the powertransformer thing with your amplifier.
I don't think you need to change the transformer, you just have to change some wires coupled to the transformer.
I'm not absolutely sure but if my memory serves me right you don't have to change the transformer.
The Sølvsuper(or Solvsuper)products from Tandberg is extremely good products. They are solid and well designed, end here in Norway you often see them still in use.
I have done some service to a coulpe of Tandbergs products, among them a coulpe of Sølvsuper models, Huldra models and some cassette decks.
In fact I did some service at a Tandberg Sølvsuper 11 yesterday, it had an problem with the balancecontrol, so I just changed the pot.
the radioparts of the Tandberg products is often extremely good, I had no problem with reciving weak stations with the Sølvsuper 11, and I also saw that this model had divided the SW-band into trhee groups, the first: 3,3 -10MHz, second: 10-20MHz, and the third: 20-30MHz.
I would also like to mention a thing I find a bit funny..
If you take a look at your Tandberg model, at the frequency dial.... you will find a city named Fredrikstad!!!... and that's my hometown, the town where I was born and where I have lived most of my life and have my family.
Fredrikstad is a town in the southern part of Norway.
vegard
yeah, the reception is amazing...
I know where fredrickstad is, Im originally from Sandnes (near Stavanger) I moved to Maryland a few years back. I love this reciever, It sounds good, and the tuner is excelent. It would be really great if I didnt have to change the transformer. I cant go look at it now, but Ill open it up tomorrow and see what the reciever looks like inside. Thanks very much for your reply. Ill let you know what Im gonna do tomorrow.
- Vegard
vegard
Is this Tandberg the same company that makes tape backup drives and monitors and stuff?
Gunderz
well.. sorry for my English, but i hope you understood anyway....
But changing the wires will do nothing :cannotbe: of course you have to couple the transformer for 120V use. Changing wires to red or green, thck or thin will not solve this problem:D
Gunderz
Well... the Tandberg compnies you see today is not exactely the same company who made those famous radioes.
The orginal tandberg went bankrupt sometime in the 70ties, but some investors bought the Tandberg label and is today mostly known for tapestreamers, monitors and videoconferencing.
vegard
Yeah, I understood. Dont worry, your english is great. If you snuck in some norsk, that would OK with me anyway!
THanks, cya
vegard
Just looked at the transformer... thats a really easy fix...
question: the unit is not grounded. Should I connect a ground to the chassis?
Gunderz
hmmm.. you said it was OK for me to write in Norwegian....
Så da går jeg over til å gjøre det.
Det å koble transformatoren for 115V er nok ikke så vanskelig nei.
Når enheten er kobla for 230V så ser en to ledninger som kommer inn fra 230V og er koble på transformatoren og en ledning på trafoen som kobler sammen to vindinger slik at disse er seriekoblet.
Her må en altså bytte om litt slik at disse blir parallellkobla.
Når det gjelder jording så vet jeg ikke helt hva som vil lønne seg. Jegh la merke til det samme ved Sølvsuper 11, at denne ikke var jorda, om det er noen spesiell grunn til dette vet jeg ikke.
Om du skal jorde eller ikke kan jeg heller ikke svare direkte på.
Page generated in 0.085125923156738 seconds with 17 queries,
spending 0.00802302 doing MySQL queries and 0.07710290 doing PHP things.
