| Where to get transformers for 41hz amp designs? - Click HERE for Original Thread |
| nukegoat |
| I'm really not having a lot of luck searching. I was looking at building some of the designs on 41hz.com but the designs that have the power supply built-in require a transformer. I really am not having much luck figuring out where to get one from, how much I should expect to pay, etc. Can someone point me in the right direction? Thanks! |
| error401 |
| I used PartsExpress to build my AMP5. The transformer I chose was part number 122-615, 160VA +/-22V. Driving 8 ohms it works well. |
| fdeck |
| I also used the 160 VA, 22+22 from Parts Express, for an AMP1 kit running in bridge mode. I ran it at clipping into an 8-Ohm load for an hour, without excessive heating. Of course to be safe, you would still want to run your own tests to confirm my result. |
| nukegoat |
| Thanks, all. Now why isn't 41hz' site working so that I can spend my hard earned money? :) |
| Andrewbee |
I have used the Antek transformers exclusively. Nice transformers at nice prices and John is easy to deal with.
The 41HZ site had a HD crash in the server. Should be back soon.
Andrew |
