but rabbit has done a redesign on it so it is a down firing port [ he is unavailable at the moment due to illness ]
my problem is how to measure the centre line to make sure the length is right
if its not right how do i change the length of it do i change the size of the corner pieces .
maybe i should just make it & hope for the best thanks for any help
Ron E
length is approx:
56+2*(374-112)+112+374-2*112+fudge
=842+fudge
fudge would be due to the effect of the area under the enclosure, which is not super simple to predict. You pretty much need to cut and try. Moving the point of entry into the spiral is the only practical adjustment.
Page generated in 0.018455028533936 seconds with 17 queries, spending 0.00769162 doing MySQL queries and 0.01076341 doing PHP things.
