diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Subwoofer with Tangband W8-740 - Click HERE for Original Thread
norrback
Hi
Have anyone built a successful subwoofer with the cheap tangband w8-740 woofer?
I saw a thread in a swedish forum where user secanbj is building a sub with this speaker but it's many years ago, now i can't find it.
If I remembered right there was no damping inside the box, but I'm not sure. So if you secanbj see this post can u contact me, i have no rights to send mail cause I'm new on this forum.
/Andre'
leadbelly
There are *many* that have been built on this forum. Did you search at all? Note that with our tricky dicky search engine you should be searching on the string W8?740C
norrback
did search but I didn't knew your tip, thanks.
Petter Persson
http://www.hififorum.nu/forum/topic...TOPIC_ID=30959.
The swedish thread, but written by its designer "Lenn Art"
Petter Persson
I found his homepage, in english
http://www.lennartlabs.se/projects/ulbox/ulbox1.htm
/Petter
norrback
that's not the one I'm thinking of. lennart is also the designer of thisone but it has an rectangular port at the bottom of the frontpanel.
fmw63
http://www.hififorum.nu/forum/topic...&TOPIC_ID=40179
norrback
thanks, thats the one I was talking about.
There is no damping material in the box, should it be without or have they just forgot to mention that.
MPM
www.billfitzmaurice.com
I've built the Tuba 18 with a different driver but the plans have the specs for using the TB driver if you want to. My tuba sub works great.
norrback
yes, I had once the tabeltuba with a peerless10" sounds great, but it was to big for me.
I've finnished my LennartLabs box with a tb w8-740 now an it sounds great.
secanbj
have not forgottrn to talk about damping as there are no damping in the box :)
Page generated in 0.026110887527466 seconds with 17 queries,
spending 0.00552678 doing MySQL queries and 0.02058411 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
