diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
SG3525 feedback with opto - Click HERE for Original Thread
medogrizli
If I use feedback with trimer resistor I can trim all range of voltage output:
IS IT possible to vary all range of output voltage if OPTO is used, and what kind of circuit is required:D
shortycap
Hi medogrizli :),
What did you use to model your SG3525?
I am currently using a student PSPICE Edition and have not found
the model. I am not quite familiar with simulations and am truly lost. :smash:
~América
Eva
If you use an optocoupler, you will also need something providing a reference voltage to which the output voltage is compared. Then the difference between those two voltages is converted into a proportional current, some gain may be added (a TL431 is the usual way), and then this current is fed to the photodiode. With such a feedback scheme, adjustable output requires just a variable voltage reference.
Page generated in 0.015697002410889 seconds with 16 queries,
spending 0.00588894 doing MySQL queries and 0.00980806 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
