| claiborne |
I need 1 selector knob from a GFP-555II preamp.
I believe it is the same as the treble,knob,bass knob etc. and was used on many Adcom components over the years (the newset pre-amp I looked at on the Adcom site still had similar knobs.)
I would even buy a set (5)to get them all to match. Thank you!
If anyone knows of a place that I could contact that sells parts that would be a big help.
-claiborne |
| Javachip |
I have a GTP-500II tuner-preamp that I do not use anymore. The whole unit was working as of 2 years ago, except that one pair of main outputs (I don't remember if it was Lab or Normal) had a buzz, and sometimes the unit would turn itself off and on randomly. I tried cleaning the main power switch and the problem improved but did not go away completely.
The balance, bass, and treble knobs work fine. See the pic to determine if this is what you need. If you just need the plastic thumb pieces, I can pull them off the switches and mail them to you for a few bucks. Otherwise, you can have the whole tuner-preamp unit for the cost of shipping.
I also have a GSP-560 Pro Logic surround processor with built-in 3 channel amplifier. It might still work -- I don't remember. There is not much demand for Pro Logic I anymore, so this would basically be for parts.
Send me a private message if you're interested. |
| claiborne |
Thank you! Those are the exact knobs I need...I really just need the plastic thumb pieces if that is ok.
I am missing one but I will take all three if you'll part with them. In case there are minor color differences I don't want the replaced one to stand out.
Just tell me how much you need for them and I will paypal or send it to you right away.
Thank you so much!
-claiborne |
| Landoctor |
Javachip,
Can you please e-mail me about the above pieces of equipment and what you want for them after you send the knobs to claiborne? I am in California also (Sacramento Area).
Thanks,
Donovan |
