diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Sonic Impact balance problem? - Click HERE for Original Thread
nukegoat
Hi - I've been lurking around but into audio for a while. Anyway, my class a/b generic amp started blaring out square waves and so while I RMA it I figured I'd check out a SI T amp since I've heard a lot about them for a while... I'm pushing a pair of Audio Nirvana Super 10's with it, so the low power output is fine. Anyway, at low volumes, only the left channel comes on... then at minor volumes, the right starts to come in, but it always seems to lag about 5-6dB behind the left. Has anyone else had this problem? How can I fix it? Are the batteries I put in on the right side weaker? :)
panomaniac
Sounds like a problem with the volume pot.
Just how good a pot did you want in a $30 amp? ;)
Only way to fix it is to replace it. But hey, you wanted to mod and upgrade anyway, right?
nukegoat
Well - My other thought was maybe I could just eliminate the volume pot altogether...
panomaniac
That would be a good idea, if you have a preamp. No need for 2 volume controls.
Do you run yours with a preamp?
nukegoat
ahh no - but i'm feeding it an input signal from my computer... I know it's not the best but I can adjust volume with the computer, no?
gychang
quote:
Originally posted by nukegoat
Hi - Anyway, at low volumes, only the left channel comes on... then at minor volumes, the right starts to come in, but it always seems to lag about 5-6dB behind the left. Has anyone else had this problem? How can I fix it? Are the batteries I put in on the right side weaker? :)
I had the same problem and sent it back for replacement. Guess this is why so cheap, since than I messed it up trying to mod. Long story...
gychang
eclectic2k
nukegoat,
yes, you could control volume with the PC with no problems I'd say - however, it's possible that might be as bad for sound quality as the cheap volume pot (though much better for balance I'm sure)
just be careful when you power everything up where that software volume is set!
I recently ran across a short basic comparison of operating system volume controls here:
http://www.benchmarkmedia.com/compu..._usb_audio.html
but then there are a huge number of variables in the PC world anyway, so depending on your audio card/ouput your software etc... this may be better or worse - so try it and find out! - heck running through the T-amp, it can't be that big of a deal ;-)
nukegoat
I think my ears are more sensitive to peaks and dips in frequency response than they are 110 vs 120 s/n ratios. People talk about the virtues of the t-amp over standard class a/b as if it's night and day... to me it's inframarginal, I can't even hear the difference... I wonder if I'll get banned on this board for saying that, though...
Thanks guys
BWRX
You are being deleted as I type... ;)
nukegoat
quote:
haha... it's not to say I won't continue buying the film and foil caps, refusing to use anything other than 12awg wire and being picky about the quality of interconnects - i just know that technically someone could switch most of those things without me knowing and I'd never figure it out. I guess years of SPL competition ruined me
Page generated in 0.02996301651001 seconds with 17 queries,
spending 0.00600791 doing MySQL queries and 0.02395511 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
