diyAudio.com diyAudio Forums Archive > Top > The Moving Image > LCD
Can I use this LCD to make DIY? - Click HERE for Original Thread
xyz123
This LCD has some features:
Function:
Screen size: 7" (diagonal)
Ratio: 16:9 wide TFT screen
Optional 4 display modes: 4:3<-->16:9 <-->16:9 Zoom<-->4:3
Resolution (H x V): 1440 x 234 = 336,960 dots
Color configuration: RGB stripe
Video system: PAL/NTSC auto conversion
Video input signal: 1.0Vp-p, composite video
2 Video inputs & 1 Audio input
IR remote control
Full function OSD control (Multi-language)
Audio output: Speaker built-in & earphone jack
Reversible screen: X-turn (mirror picture) & Y-turn (flip-down picture) available
High resolution and no radiation (better for eyes¡¯ protection)
DVD/VCD/Security system/Navigation system/Rear view camera compatibleMount type: Stand-alone
LCD Brightness: 300cd/m2
Contrast: 150:1
Viewing Angle: 45/60(U/D), 65/65(R/L)
I mean the Resolution, If it is good, I intend to use with 2 lapms 400w, Projection Len = 320 mm; 4000 Lus ( Get from Apollo Overhead
brian4
:smash: Hello
You will need to have a look inside the lcd box.
Look for cables etc that might get in the way of the light path.
Will the lcd backlight come off ...
The screen specs are good for a diy PJ.
Brian..
Page generated in 0.026263952255249 seconds with 16 queries,
spending 0.01362705 doing MySQL queries and 0.01263690 doing PHP things.
Copyright ©1999-2009 diyAudio.com
