diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
How to wire a balance control - Click HERE for Original Thread
Bama Slamma
How does one wire a balance control? Since I now know where to get a dual-gang log pot, I'm thinking of getting rid of the dual volume controls on my amp and having a volume and a balance control. Is a balance control done with a dual or a single gang pot and how do you wire one?
gmphadte
A linear pot is needed to be used. U have to ground the wiper, and connect the other extremes to the two channels through a resistor per channel, so that the signal does not get shorted to ground. This has to be fitted before the volume control IIRC.
Gajanan Phadte
Nordic
From ESP Audio
Because of potential ground loop issues.. I will next time use a dual pot as a master volume, and 2 single pots for level adjustments.
richie00boy
Just use a dual pot and forget about balance controls. They are a waste of time.
Nordic
quote:
What a nice listening room you must have.....
richie00boy
It's nothing special.
Balance controls are a waste of time because they only change the level not the phase, i.e. they don't compensate for distance differences. They are a gimmick leftover from the 1960s. The less pots in the signal path the better.
AndrewT
The less any/everything in the signal path the better.
Just keep the bits the circuit really needs.
Bama Slamma
What value should the resistors and pot be? My dual volumes are 10k apiece.
Bonsai
Bamma Slamma, when you go to a live show, you do not have the option of a balance control.
Take some good advice from the guys above that suggest you do not use it, and rather spend your money on the best quality dual volume pot you can afford.
Page generated in 0.052068948745728 seconds with 17 queries,
spending 0.01203394 doing MySQL queries and 0.04003501 doing PHP things.
Copyright ©1999-2009 diyAudio.com
