diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
power supply problem pop noise - Click HERE for Original Thread
prorms
iam using a lm317 lm337 circuit
keep getting pop noise every 15 sec
7volts and -7 volts
prorms
prorms
basic diode setup 4 diode
transfomer 14vct 0.250 mA
prorms
opamp iam using are opa134 lf351 iam have connect with no resistors just stright in
Dzsoni
Every 15 sec? Strange... LLOks like a capacitor-problem...
Value of PS caps in uF?
About 1000uF would be OK.
[On the margin I would use much higher rails for the OPAs, say +/-15V.]
prorms
was not the power supply section but it was the last part
of the preamp that goes to the power amp
preamp on its own powersupply and circuit form the power amp
in stead of using diff voltage i use like a battery
Page generated in 0.018769979476929 seconds with 17 queries,
spending 0.00698638 doing MySQL queries and 0.01178360 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
