diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Which 12" sub for sealed box - Click HERE for Original Thread
rca9449
I have a speaker cabinet in beautiful wood veneer that I want to make a subwoofer out of it - actually I have two of these cabinets but only want to experiment with one first. It is about 5 cubic in volume and has a slot for a 12" (I will use a piece of wood to seal the tweeter slot and mount a plate amp on the back.) Which 12" woofer would you recommend for a simple large sealed box. I have a budget of $50~$120 - the least expensive the better as I may do two for stereo sub should my first sub become successful. Thanks in advance.
tinitus
Its bigger but would suit your box
http://www.partsexpress.com/pe/show...tnumber=295-130
But I am in doubt about it ... with two of these and the needed plateamps you might be better off investing it all in 15" servo sub kit from Rythmik
Page generated in 0.017712116241455 seconds with 17 queries,
spending 0.00706029 doing MySQL queries and 0.01065183 doing PHP things.
Copyright ©1999-2009 diyAudio.com
