diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Inverting FET openloop gainstage - Click HERE for Original Thread
Onvinyl
I made a sketch for an openloop stage with ~30dB gain.
Sim only, for the moment.
This is how it works (at least, how I understand it does...):
The heart of it is complementary version of a grounded gate diff-amp with 'no' miller effect (or it would be with R1/R8 = 0).
The cascoding FET's (J4/J8) shouldn't show a miller effect as well, but without Q1/Q2, high-Freq rolloff starts very early at only some Khz. With Q1/Q2 present, it's no earlier than 70Khz (see next posting).
FET models sim a IDSS of 14.8mA, so I real world biasing would show different values for some parts.
J6 is present for convenience in the real world when finding the optimum base voltage for Q1/Q2.
This cascode connection has been used by borbely, curl, pass and many others, it is discussed in the A75 article and in the new borbely-papers, for instance. There is a patent of M.Noro which goes into details as well (all infos at diyaudio.com :)
Because the circuit depends strongly from any load, it needs buffering.
I'm looking forward to build it.
Unfourtunatly, I don't know how to perform square-wave tests oder distortion measurement in LTSPice to look for fundamental errors.
A few questions:
-Why is miller effect still present at J4/J8?
-How to calculate the optimum load (R12)?
- How can I adjust the fet models, so I can set them to my real world devices (a bunch of 2sk389/2sj109 around 6-9 mA IDSS)?
thanks,
Rüdiger
Onvinyl
<output bandwith>
john curl
Why include an output stage at all? Think about using it as a transconductance amplifier.
Onvinyl
I build the real circuit (without output follower), and while the sim with LTSPice showed wildly different dB-numbers for very near values of Rl, the real circuit is much more robust against loadchanges.
If all fits, it shall drive the 50/500 pole of a riaa network.
At 23.5dB, it puts out fine waveforms (no distortion measurement gear at my command, sadly), a 20 Khz square wave is, well, square.
Sadly, I have too few V-grade FET's. I guess it's best to switch for beefier parts for the cascode, with my 11mA IDSS parts I have to go down to 2.5mA for the input pairs to get best waveforms.
Rüdiger
Onvinyl
now I build the attached circuit. Other than indicated, the input pair are 2sk389/2sj109 with an IDSS around 7mA running at 6mA. The cascode fet's take 11mA, the bjt's take 9.
The ouput sits at 300mV DC at the moment, gain is 100. The square looks perfect till 70Khz and slowly rounds till it loses gain at perhaps 300Khz.
It is perfectly stable, power on and off are very smooth.
Can't wait to actually hear it.
Rüdiger
Onvinyl
sorry, bjts sit at 12mA
CBS240
Hi
It appears to me that the input capacitance of the j-fet is much greater than that of the BJT. The input impeadance of the BJT may be lower at 0Hz because of base current but it is more resistive, so when viewing higher frequencies like in that 70KHz SW, the input capacitance of the j-fet used as the gain stage loads the input differentials more, reducing dV/dT. Try using the BJT's as the gain stage and the j-fet's as followers. R3 could be eliminated since the j-fet follower is self bias, with source resistors. This way the BJT's, with a lower impeadance, are driving the j-fet input capacitance instead of the input stage. Also you could try BJT's for the gain stage and follower. Might have to adjust R1,2,8,9 a bit though but I would be interested in the simulation results to see if it is faster.:)
:2c:
G.Kleinschmidt
quote:
You really need some emitter degeneration here to define the quiescent current through the BJT's. I'm actually surprised that you haven't smoked them yet. Consider ~10 ohms on each emitter and perhaps even replacing R3 with a series pair of 1N4148’s or similar.
Glen
Onvinyl
quote:
Glen
Well, I *did* smoke them, when I made R3 too large...
I will try all suggestions as soon I have the time!
Rüdiger
edit: yes, I did try it with two bjt's, it *is* faster but it gave me some problems that looked like ringing. I will investigate further.
CBS240
It looks like R1/R8 degenerate J4/J8, the question is, to what degree? Some degeneration on Q1/Q2 is still a good idea.
Onvinyl
The case is different if you use fets or bjts in the fc-position.
As shown, the cascode fet's take 11mA. If you omit R3, almost all the current flows through the fet, by enlarging R3's value you balance the current between bjt and fet.
Q1/Q2 don't seem to need any degeneration.
It's not easy to predict the DC behavior without sim (or build) because of the interdepency of the biasing. The voltages that appear over R1/R2 set the Vgs of the fet which sets Id which in turn changes the voltage drop over R1. The DC-behaviour is stable, however. If you change R1 you change, of course, the net current of J4/Q1, by adjusting the value of R3 you split the current between the two. I couldn't see much difference in the output-waveforms for any reasonable current split. Will see later, if it changes sound.
I made a quick sim, with interchanged fets and bjts in the cascode, R3 can indeed omitted and it indeed has better shaped sqw and extd. bandwith.
I'm running out of time however, I will try the interchanged design in a few days on the workbench.
Rüdiger
G.Kleinschmidt
Rüdiger
Ok, having a closer look at you circuit this time, I see that the collectors of Q1 and Q2 return to the JFET sources to make a kind of symmetrical CFP.
My previous post can be disregarded.
Glen
Onvinyl
The circuit runs most smoothly when keeping the fets in the folded cascode position (with added resistance between both drains) then driving mosfets (instead of BC550/560). I could even drive my headphones with it (okay, this steels some gain) when I used irf610/9610. With shunt regs running at +/- 24V it sounds real promising!
Rüdiger
lumanauw
Hi, Onvinyl,
How stable is the DC bias? Does it need a servo?
Onvinyl
Hi lumanauw,
still, it is not a final design.
The DC-workingconditions seem stable.
The output sits at 300mV yet, and is dependent of the load that is presented to its output. As is the gain and linearity (transconductance amplifier).
The output mosfets are not matched yet (the other fets are), so it will maybe better in the end. It will need a servo, I think.
One could fineadjust R9, for instance, but that corrupts AC-behaviour according to the sim.
More ideas are welcome.
Rüdiger
lumanauw
Hi, Onvinyl,
Why you make it inverting? Is it for special purpose?
Onvinyl
inverting was not the primary goal. The idea was to use the diff pair in a 'no-miller', or perhaps, less-miller mode. See first posting.
Rüdiger
AndrewT
it is inverting as shown.
Swap the inputs and it becomes non-inverting?
Any downside?
Since there is no GNFB, the two inputs are identical making it very worthwhile taking both to the input plug and grounding the unused input at the input socket.
Even better, use an XLR and two core and take the unused input all the way back to the source unit and ground it inside the source.
Heck, go fully balanced.
Lumba Ogir
Hi Rüdiger,
For the second time in just two weeks: nonlinearities in JFETs are basically caused by varying, high parasitic capacitances which can be effectively reduced by keeping Vds constant. Limiting their operating area at the same time is important too. Cascoding can provide that and several other advantages, when applied properly. It is no the case in your design so do not expect much.
Have you finished the other input stage yet?
Onvinyl
Any downside?
Hi Andrew,
if I swap the inputs, the bandwith suffers. Again, AoE, where they discuss the miller effect.
Yes, the balanced option springs in one's face, but I'd lose the non-miller benefit.
It's intended for as the second stage in a phonoamp which does not go balanced. A balanced circuit could be made, as is thoroughly discussed in the blowtorch thread.
Hi Lumba,
we have a variation of the folded cascode here. Further cascoding of the input pairs as well as the FC-pair yields no benefit, according to all the things I tried.
My input stage waits till I matched some fets. Matching is ... boring.
Rüdiger
Lumba Ogir
Rüdiger,
your statements regarding bandwidth and some other things are very confusing. To me, the FC is nearly worthless, a particularly ineffective linearizing mechanism. One way to increase the bandwidth would be reducing the extremely harmful Miller capacitance you are looking for. The FC will do nothing about it at all. It is useless.
Onvinyl
Lumba, did you read my posts?:confused:
Lumba Ogir
Rüdiger,
Not very accurately.
What is the impedance of your headphones?
Onvinyl
my headphones are Sennheiser HD560, I guess they have 300R impedance. I ran both sides together, so it goes down to 150R.
Note I don't think it really qualifies as an headphone amp, a square wave gets nasty overshoot spikes. The sound is amazingly good, though.
The gain goes down from ~40dB to 28dB.
Anyway, I am most surprised that you think a folded cascode does not work like a cascode regarding linearizing the cascoded device.
To me, a cascode qualifies as one, when current- and voltage swing are divided up in two devices, in the way that the cascoded device provides current gain and the upper device performs the corresponding voltage swing.
The mixed mode I use here is not my invention, it has been used by John Curl, Nelson Pass (in the A75) and Erno Borbely (in his last articles).
Rüdiger
Lumba Ogir
Rüdiger,
the only thing I like in your design is the lack of global NFB. Maybe you should forget about it and concentrate on the other one. Start matching at the intended Vds bias (4-5V) using about 150 Ohm source resistance.
Disturbingly, you are often referring to simulation data having no relevance to the sound. I do not give a dime for those.
300 Ohm impedance is favourable from a practical viewpoint. A suitable output stage could be:
Onvinyl
Hi Lumba,
*Which* data is only simmed? Anything presented here is confirmed by acutally building the circuit, and sim is pretty close to measurement (which is limited, because I only have a scope and a sig-gen).
I even listened to it using the circuit as an headphone amp. For clarity I'll post that version here.
You say FC is worse in linearizing the input devices, but you don't say *why*. It would be great if you do.
From all I read, your assumption that FC does nothing against miller must be wrong.
With R1/R8=0, Miller would be completly absent without cascode. Of course, deltaV against deltaI would be still a problem.
Why do you think I need source degeneration in the output?
Rüdiger
Lumba Ogir
Hi Rüdiger,
the purpose of cascoding is to improve linearity, bandwidth, gain, noise, load impedance, ripple rejection, to provide insulation and to prevent thermal related distortions in those highly sensitive chips. Nothing of that is achieved with the FC arrangement. Vds must be kept small and firmly locked by applying a stable, low impedance reference voltage to the drain and source terminals. Not using any source resistors is very unwise.
The CFP has an inherent powerful linearizing mechanism, much more powerful than folded cascodes, NFB or dubious, complex and deteriorating error correction circuits. It can use up to 100% voltage feedback, working in an effective, direct and precise manner without any additional parts whatsoever, thus allowing a clean and straightforward signal processing. For its operation and stability, speed is essential. Therefore, regarding the output stage, lateral MOSFETs and high voltage, fast bipolars with very low Cob as drivers (from Sanyo or Toshiba) are the best choices. As the drivers being referenced to the output, the output impedance is low. Please note, those resistors are not in the source line.
Avoiding NFB gives important sonic advantages and can be done successfully, but not easily. Considerably more attention to the details needs to be paid.
Onvinyl
Hi Lumba,
I re-read some of the stuff related to folded cascodes and tried some things. It seems to me now that you raised valid points. Even if a folded cascode *does* fix the voltage of the cascoded device, the remaining bit seems distorted, which is not the case with conventional cascode, for instance. The fc is not famous for very low distortion...
The fc still has appeal, since it overtakes two functions in a single device: cascoding and VAS, even if flawed compared to more-stage solutions. Linearizing the FC-Q makes things a bit better.
The discussed circuit here should be used as a second gain stage in a phono amp, so I will try other solutions as well. Especially the cfp-input-pair-threads draw my attention.
thanks,
Rüdiger
Onvinyl
Once again, I stumbled over the UGS-thread and I thought that it may be a good starting point for my purpose.
Below is a first sketch.
Gain might be a bit high (around 59dB), and although I followed the instructions posted in diyaudio sometime ago, I couldn't persuade LTSpice to compute distortion numbers for that (or any other) circuit. It might not be too useful if I could, anyway.
I will build it and report.
Any advice or comment would be welcome, even if negative (I'm used to it). :cannotbe:
Rüdiger
Page generated in 0.068304061889648 seconds with 17 queries,
spending 0.00537467 doing MySQL queries and 0.06292939 doing PHP things.
Copyright ©1999-2009 diyAudio.com
