diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Help with control a Stepper motor with an IR-control. - Click HERE for Original Thread
Progg70
I’m trying to find a fast way to build a circuit there I can control a Stepper motor with an IR-control.
I have a nice circuit but then I need a equivalent part for SAA1027-PHI, the driver part.
Someone who can help me?
error401
I'm not aware of a source for SAA1027, but there are lots of other ICs that perform an equivalent task. They won't be pin compatible, but it should not be hard to find a functional equivalent.
For example the MC3479 is pretty much a drop in replacement from a glance at the datasheets. It's not pin compatible, but it has all of the same functionality. It's a bit pricey, but easily available from DigiKey.
I've seen some kits that read from IR and give you logic outputs. With a small amount of glue you should be able to use this to drive a more 'traditional' stepper driver (with onboard monostable) easily. No links offhand though.
Page generated in 0.27240490913391 seconds with 16 queries,
spending 0.16367102 doing MySQL queries and 0.10873389 doing PHP things.
Copyright ©1999-2009 diyAudio.com
