diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
psu of 65v to 12v - Click HERE for Original Thread
widi
hello friends I am constructing an amplifier which is fed on +-65v, and want to feed I modulate of protection of loudspeakers that works to 12v. as I can turn the tension of 65v to 12v? somebody can give an adjustable scheme me of one psu to adapt it to my source of 65v to obtain those 12v.
Thanks and greetings.
Nordic
Why not just use a small PCB mount transformer... they are realy small, like 2 boxes of matches... and should only be $2 to $4...
AndrewT
quote:
Originally posted by widi
.......protection of loudspeakers that works to 12v. as I can turn the tension of 65v to 12v? somebody can give an adjustable scheme me of one psu to adapt it to my source of 65v to obtain those 12v.
give us a few clues?
Dual polarity or single.
How many mA @ 12Vdc?
What peak current might be required?
Are there any big current consumers like relays?
widi
Hi thanks, first of all good is like I have said for a protector of loudspeakers of a multi-channel system and are seven independent protectors with its seven relays, pense to mount an independent source with its transformer since our Nordic friend has said but my problem is that the positive of the protector is the negative of the loudspeakers and I do not want that is no type of noises, for that reason want that the feeding leaves the same source of the amplifiers. The protector of loudspeakers does not surpass the 1.5 amperes, pense in using the famous LM317 but they do not support an entrance of 65v.
I wait for your aid
AndrewT
answer to question 4 is 1.5Apk,
answer to question 5 is 7 relays.
tell us more.
But first guess is Vdrop = 53V
max current =1.5Apk
Pmax~=80W. i.e. sink on the regulator is bigger than the sink on the main amplifier. :xeye:
widi
The total consumption of the circuit with the seven activated relays is of 1,2 amperes RMS, has a circuit of protection by each channel. The power supply of the multi-channel amplifier is of - +65 volts and 45 amperes.
I hope that with these data they serve to you as something
djQUAN
simple. use a separate transformer. then a negative supply after that. since it will be isolated, there should be no noise issues.
Page generated in 0.025347948074341 seconds with 17 queries,
spending 0.00841475 doing MySQL queries and 0.01693320 doing PHP things.
Copyright ©1999-2009 diyAudio.com
