diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Silence audio o/p - Click HERE for Original Thread
bimbla
In audio circuits, the control circit invariably produces some sort of hum. No matter what you do, getting silence at the
output is very difficult.
What are the different ways to obtain silent o/p? I autoroute my boards having control and power sections on the same board
using Layout Plus.
I am using amps in bdg configuration in the final stage. Instead of bridging it in the amp circuit itself, I plan to invert
the final control signal and feed the complementary signals to two identical amps.
I hope that this will eliminate the common mode hum. I also hope that this will eliminate the need to have a turn- on delay
circuit along with the bulky relay.
All comments and views welcome.
bimbla.
halojoy
Hello bimbla
With control you mean Volume control ..
Or do you mean Protection Cicuit?
If you draw a simple Picture of your circuit
or the way you plan to do,
I think you get some good advice.
/halo
EC8010
quote:
Originally posted by bimbla
In audio circuits, the control circit invariably produces some sort of hum. I autoroute my boards having control and power sections on the same board using Layout Plus.
Well, there you are. Letting an autorouter loose is asking for trouble. Any software that you or I can afford will not be as good as thoughtful human layout and invariably uses tracks that are too narrow, too long, and too convoluted. When you lay out a board, you can consider factors of which the software is ignorant.
Try widening tracks, shortening tracks, avoiding mixing control and audio currents in tracks, and adding grounded guard tracks between noisy and sensitive areas. Realistically, PCBs are a production method, and require a huge amount of thought to achieve optimum performance. When I use them, I lay mine out manually...
Havoc
I second that: never autoroute audio circuits!
First, identify your signal path, any high impedance nodes, low level, high level and your power path. Next, try to layout your circuit so that the signal follows a "smooth" route from in to out (like in on one side, flowing stage after stage to the other side where the output is). Also try to keep high impedance nodes away from high level circuits, power from low level.....Then layout each stage for minimal loops inside (like feedback....) Next, choose a grounding scheme that will simplify your routing while eliminating loops. Then get power to each component keeping the loops that carry a lot of current small and out of the way.
Next stage is putting it all in a box, keeping all the above in mind.
Brett
I third that. Do it manually.
quote:
originally posted by bimbla
In audio circuits, the control circit invariably produces some sort of hum. No matter what you do, getting silence at the output is very difficult.
I use speakers with about 105dB sensitivity, and my system is tube from MC cart to poweramp output, and I don't get any hum. It's about getting the detail of the layout right, and if you're not very experienced at it, unfortunately it might take a few attempts.
e96mlo
If its LF-hum you are experiencing then it might be bad grounding and insufficient decoupling.
Well, I too have to agree what the other guys said about autorouting. It sucks! I've seen experienced(?) engineers in the industry trying to autoroute, for example PSUs, only to have to rip it up and do it by hand.
/Marcus
Page generated in 0.029041051864624 seconds with 17 queries,
spending 0.00807977 doing MySQL queries and 0.02096128 doing PHP things.
Copyright ©1999-2009 diyAudio.com
