diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
l.e.d's - Click HERE for Original Thread
impsick
So i want to make some crazy led flash light but im not to sure what kind of leds should be used. You know they say they are super bright, or brilliant or what not. So what should i look for in the led, rating wise or key words? Thanks
richie00boy
Most lumens output you can find. Check dispersion/directivity as well, depending how narrow the beam you want.
impsick
ok, whats a good number of lumens? i see 50, 80, or then there is Luminous Intensity (mcd) which is in the ratings like 1500 to 10,000 and up.
View angle 25 degrees. is that something to do with dispersion?
Page generated in 0.020225048065186 seconds with 16 queries,
spending 0.01066732 doing MySQL queries and 0.00955772 doing PHP things.
Copyright ©1999-2009 diyAudio.com
