diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Make a preamp with an already buil amplifier - Click HERE for Original Thread
fabinto
hello everybody
Can you help me to take the audio signal in my amplifier to an output RCA for just
préamp (no power signal).
My amp is
For préamp 2 X 6n3 tube
For amp 4 X EL84 tube
Where can i take the signal (on the two 6N3 ?), must a put some resistor to have the good impedance ?
I would like to make
CD player---->preamp (amp modified)------>another power amplifier or mixer...
Sorry for my english
Best regards
Fabien
d2134
Can you post the existent schematic?
kevinkr
quote:
Originally posted by fabinto
hello everybody
My amp is
Best regards
Fabien
It doesn't sound like this design has a dedicated pre-amp stage from your limited description. I assume the signal goes straight from the volume control right into the first stage of the power amplifier. The 2 6N3 are part of the driver circuitry of your amplifier - EL84 is a single power pentode unlike say the ECL86 which is a triode/pentode. You'd be better off building a little line stage for this application - a good diy first project IMHO.. :D
Page generated in 0.020368099212646 seconds with 17 queries,
spending 0.00683022 doing MySQL queries and 0.01353788 doing PHP things.
Copyright ©1999-2009 diyAudio.com
