diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > ESLs, planars, alternative technologies
Base driver to suit ESS Heil driver - Click HERE for Original Thread
gerado
I am interested what fellow DIYers suggest will be a good base driver match for the smaller Heil driver.
I bought a pair of these speakers new in my youth, but even back then thought the base lagged behind the oh so liquid character of the Heil driver. The base drivers and cabinets are long gone but kept these beautiful sounding tweeters.
I wanted to match them up in a smallish enclosure with 8-10 inch base driver that can actually keep up with them.
Not too fussed about going down real low (40-60hz and above is ok) and sensitivity of 90db and above.
Any suggetions of a "killer" base driver and where to source it from?
Al.M
I am guessing but if you have the small Heil tweeters maybe the ideal crossover point is around 2500hz or 2000hz. What do your Heil speaker specs say? With the bigger Heils ESS often crossed them over too low around 800hz, whereas 1500hz was better.
Perhaps stick to 8" driver as you are likely to be able to crossover higher. Maybe even 6-7" driver better. Many 8" would only be good up to 1500hz max. Check the driver specs on Peerless, Vifa P17, if you want to spend more try Scanspeak 18w/8535, 18/w/8545, Seas 22w Ex002(?) might be best choice although not much good above 1500hz etc.
gerado
Thank you AI.M
thats good to get me started.
I dont have any specs on them unfortunately. They are the smallish brick shape drivers with a single front diaphragm, and a silver front cover. The original boxes had about 12inch woofers with rear passive radiators in "booshelf" cabinets. Though I have never come across a bookshelf big enough to fit them :)
which would be your preference of all the ones you suggest based on sound quality and ability to integrate best with the heil?
thank you once more for your help.
Al.M
The Seas is probably quite good but more expensive than others.
tinitus
Thinking about HEMP or ToneTubby :scratch1:
gerado
do not quite follow you HEMP? ToneTubby??
tinitus
With the ToneTubby I have my doubts how I would handle it with its high Qts and low Vas, and at some time there was a rave about it, but we have heard nothing fore a long time
With the Hemp I thought about the 8" FR8C, maybe in a MLTL
http://www.hempacoustics.com/products.php
Dave(planet10) has shown a nice twofolded quaterwave, where you could place your ribbon on top, but dont remember where I have seen it
Maybe AudioNirvana 10" or 12" could do it too, but I think the FR8C will be the better one, and a quaterwave will be the way to go
Page generated in 0.030241012573242 seconds with 17 queries,
spending 0.00808764 doing MySQL queries and 0.02215338 doing PHP things.
Copyright ©1999-2009 diyAudio.com
