diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Partridge SE O/P transformers - Click HERE for Original Thread
Stef
I have been playing with a 300b Thorsten Legacy design using conventional power supply (CLC) with two different output transformers.
The first was a AudioNote AN144 cheepo trx which sounded quite nice and balanced, good in the highs and ok but a bit soft in the bass.
Then I bought some TK4519 potted o/p trx's - the issue I am currently having is that this trx seems to be bloated in the bass and grainy in the treble (been running for 3 weeks now at 8 hrs a day).
Has anyone else used the Partridge o/p trx? Did you get similar results or should I keep on running the unit in and hope for improvements?
I have tried different resistor types and capacitor types to balance the sound but end up with the same bloaty bass and grainy treble - I could of course be doing something wrong?
Any help or suggestions appreciated.
Stef (UK based)
Page generated in 0.0156409740448 seconds with 16 queries,
spending 0.00794721 doing MySQL queries and 0.00769377 doing PHP things.
Copyright ©1999-2009 diyAudio.com
