diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Radford STA-15 questions - Click HERE for Original Thread
patrickamory
I just acquired a Radford STA-15 amp. I was wondering whether anyone could help me with some questions:
- Voltage selector. I'm in the US. There is a voltage selector switch, but it's confusingly marked with 3 settings:
110/220
125/235
140/250
I want 110, obviously, not 220... but I can only choose the combination, whatever that means. Does anyone know why both voltages are marked at the same position on the selector switch? Am I safe to plug it in at 110/220 in a 110V mains system?
- Has anyone restored one of these before? Any tips - obvious parts for replacement, etc.? The amp seems to be completely original.
- Does anyone have owner's manual, schematic or service manual for one of these?
Thanks in advance -
Patrick
Tom Bavis
Actually 125 is a better choice - most places have in excess of 120V these days. The 125 / 235 selection is done with an internal soldered jumper. Unless this amp came from Europe, it's probably on the lower setting. You can't hurt it with lower than rated voltage, anyway ,but I'm sure a LOT of US equipment has gotten fried on 230v!
Schematic: http://www.drtube.com/schematics/radford/sta15.gif
patrickamory
Ah, great, thanks for the schematic link!
Sorry to be dense, but do I need to go inside and move the jumper then?
I've measured about 117V at my outlet...
Patrick
Tom Bavis
Where was it last used? If US or Canada, it's set for 120V. What plug is on the cord?
patrickamory
In the UK. No plug on the cord. I'm sure it's set for European voltage.
kevinkr
Yeah, you'll have to change some internal jumper settings to get it to work here.
Remove the connection between PY2 and PY3
Connect PY1 to PY3
Connect PY2 to PY4
The above is probably obvious to you, but in case it wasn't.. ;)
IIRC these are hardwired connections that you will have to solder.. (It's been a while since I saw one of these.)
Change the fuse to 3A, medium blow type if possible.
Finally set it to the 125V position on the voltage selector switch, better to slightly under run the amp voltage wise than to significantly over run it.
How old is the unit and are you sure the electrolytics are all copacetic?
patrickamory
Thanks Kevin, I'll get to work. Amp is probably early '70s and the 'lytics may well need replacing. I noticed the fuse rating issue too. Thanks!
patrickamory
Argh, the label on the power transformer primaries turns out to be gone. It survives on the secondaries side.
On the secondaries, the tap numbers go 13-18 from bottom to top on the left, and 19-24 top to bottom on the right.
Does this order give any clue as to how the primary taps must have been numbered?
Here's a couple of pics:
1. secondaries:
1. primaries:
anyone have any idea?
Patrick
patrickamory
Ah - got it - by tracing the wiring from the voltage selector. I could barely see the jumper between PY2 and PY3 (it's invisible in the photo above) - I've now identified the taps.
Patrick
patrickamory
Up and playing music through my Quads. Thanks Tom and Kevin.
Next step: replacing the EL34s, and component check.
Patrick
kevinkr
What brand output tubes are in there now? If these are late Mullards and aren't roached they may be better than most current production.
patrickamory
Two are Mullard, one is Brimar, one I can't read (need to pull and examine more carefully).
patrickamory
Resurrecting this thread... looking at the transformer wiring diagram below, what taps should I connect to wire for 125V (rather than 110V, which I take to be 1-3 and 2-4)?
Tom Bavis
input goes to 5 and 1-3. 2-4 remain connected together.
patrickamory
Thanks - I now realize I had it right - 1-3, 2-4, and then the selector switch for 5.
7N7
What a delightful thread! I am pleased to hear that the amplifier works well.
Just want to add that I think that had he lived later, Arthur Radford could have done well in today's computer industry.
His talent for making things difficult, if this story is typical, would have been most appropriate!
7N7
bigwill
Shame my father wasn't there to help - I THINK he actually knew Arthur personally and when they closed down he ended up with many many of the parts for most of the amplifier range and continued to build and sell them. He is friends with John Widgery who started woodside electronics, too.
7N7
Radford was renowned for the quality of its output transformers. Y
Years ago, somebody (I can't remember who) told me that part of the secret was that the transformers were wound by a middle-aged lady who had been doing this for years!
7N7
Page generated in 0.057482004165649 seconds with 17 queries,
spending 0.02708220 doing MySQL queries and 0.03039980 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
