diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Negative Sziklai - Click HERE for Original Thread
timH
Can someone give me the layout of a negative sziklai please. I can only find a positive layout
Tim
Giaime
Mmm... are you talking about this?
http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm
Scroll down. The first schematic has a complete CFP output stage ;)
AndrewT
fig 1a and fig 13 C show your Sziklai outputs and the other configurations.
For anyone else listening, the Doug Self articles are excellent grounding for learners to the subject of discrete amplifier design.
I'm not suggesting copying whole schematics, but more keeping all those little ideas for when they might be needed, eg, 5.7 distortion 7, where to tap off the NFB loop, this mistake is repeated by the majority of experienced builders but should never be made by a competent designer/builder.
timH
Thanks - yes that's what I needed
Tim
Giaime
quote:
A must read :D
I perfectly agree. If you could see those errors made in $$$$ priced amps... :smash:
timH
I'm actually wanting to use the Sziklai in a VBE (or gyrator or whatever it's called)
This is the circuit I've come up with for a negative version (based on the positive circuit given by teddy-pardo over on pfm) - sorry its a bit larger than necessary
Tim
Giaime
Mmm, I think you missed out a resistor. Look at the CFP/Szilaki pair: there is a common collector driver transistor, which has a "current sensing" resistor on its collector, to drive the "bootstrap" power transistor.
So try a resistor between the lower transistor collector, and the upper transistor emitter, of 100ohm - 470ohm, you'll enhance the "cleanup" action of the gyrator.
Edit: Ps depending on the actual transistors, and the spectral content of noise to be removed, you may not need the resistor in series with the lower bjt's base.
Lumba Ogir
Giaime bouna sera,
no, your explanation is not quite correct. That "current sensing" resistor is actually current source for the PNP transistor. In this application, a series pass regulator, it can be omitted to avoid the injection of harmful ripple voltages into the sensitive base of the NPN transistor.
In other applications it is used for defined higher standing current.
jcx
quote:
Originally posted by Lumba Ogir
Giaime bouna sera,
some value of npn_be resistor is usually better than none, increased bias current in the pnp increases gain of the pnp and the R_be can speed up turn off of the npn - both improving input ripple rejection at dc and higher frequencies - the signifcance of both effects varies with transistor properties and operating conditions
timH
Thanks guys - I'm getting outside my understanding envelope with this so I'm gonna go the experimental route and try it without the base to emitter resistor first and then try it with and see if my ears hear a difference
Tim
ps problem is that they're gonna be fitted in a locally regulated pre-amp so there will be 14 of them to add resistors to :(
Lumba Ogir
jcx,
you are of course absolutely right and I am very much aware of that, but it is in my judgment, in THIS application inferior.
There is much more to say...
CBS240
Now include an error amplifier, IOW a fb loop, and you have a basic regulator.:)
Lumba Ogir
Giaime buona notte,
(especially large) capacitances should not be applied directly to the bases so it is wise to place a resistor there.
Lumba Ogir
jcx ,
right?:D
Giaime
Hello jcx,
quote:
you're perfectly right. The resistor increases the gain of the regulator, giving better ripple rejection: and this gain increase is much stronger than the inevitable ripple "path" to the transistors (of course this effect is mainly at high frequencies).
Lumba Ogir: just try to do a SPICE simulation, you'll see what I mean ;)
Red trace, no resistor: green trace, 100ohm resistor :D
Giaime
quote:
Well, that's hard. But I think, honestly, that with a good layout and the accurate choiche of passive components, that a LM317 outperforms this circuit and potentially is smaller in PCB area. Maybe, if the voltages are standar values, even fixed regulators can work in your application.
May I suggest the reading of "Linear & Switching Voltage Regulators Handbook" by OnSemi, I think you can download it for free in their own website.
My :2c:
Kapibara
http://www.pedjarogic.com/gc/supplies.htm
Kapibara
Page generated in 0.041769981384277 seconds with 17 queries,
spending 0.00509667 doing MySQL queries and 0.03667331 doing PHP things.
Copyright ©1999-2009 diyAudio.com
