diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Modding a NEC PJ - Click HERE for Original Thread
BlackFox22
I have a NEC VT470 with the light bulb gone. I was thinking of using the techniques described on this forum to use a outside light source instead of buying a new one for $299.
But the first problem, like everyone else, is tricking the projector to believe there is a ligth bulb.
Does anyone know how it senses the light is ON ? There are only 3 wires to the lamp itself (power and gnd). So it must be sensing the light or heat.
There is a IC called 67L120P right above the lamp housing as you can see in the picture. Would shorting this do it ?
Thanks in Advance
BlackFox22
I finally tested shorting some points which I thought could be the sensors. It turned they are all heat sensors. One is a detector for the lamp door.
Is it possible its sensing the current flow to detect if the bulb lighted up ?
ywh
Hi !
I have this lamp , 180w JYS/DC , I am selling it
http://www.diyaudio.com/forums/show...635#post1268635
it is cheap, only $40 each, you need intall bulb into you old reflector only.
BlackFox22
The URL is incomplete.
Can you please post a picture ? The lamp in the reflector I have is very small.
Also, is there any other mode of payment you can accept than moneybookers ?
ywh
http://www.diyaudio.com/forums/show...1&goto=lastpost
joshman1983
I have an old Sharp XG-H400U. I need a bulb to replace the old one. The bulb housing has model number BQC-XVH30U1. Could you find out what watt bulb I would need? I believe I need the JYs-SE for alternating current. Any help here would be much appreciated.
Also, I am curious to know if you are connected to www.diypro.us or are they competitors?
Page generated in 0.031922101974487 seconds with 17 queries,
spending 0.00724053 doing MySQL queries and 0.02468157 doing PHP things.
Copyright ©1999-2009 diyAudio.com
