diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
WTB: broken Nakamichi CD player - Click HERE for Original Thread
cscmc1
I have a Nakamichi CD Plater 4 with a stripped gear in the laser drive assembly. Anyone have a dead Nak they'd part with on-the-cheap? Mine is missing its remote, too, so bonus points for one of those. Thanks!
cscmc1
Anyone? Attached is a pic of the gear I need (the one my index finger is resting on). Thanks!
Westley
Hi. This is a Sony assembly and that gear is a common problem. I will email you the Sony part number after I get home where I have the S/M. It is not expensive and I recommend replacing all three gears while you are doing it.
cscmc1
Thanks Westley!!! Would this likely be the sole cause of the mistracking the player is experiencing?
Westley
Yes. It is a common cause as the teeth wear on the gear, bits of the teeth get stuck causing the pickup to lock or miss the tooth resulting in the mistracking. If you check the gear on the motor closely and there are no teeth missing or disformed, you will not have to replace that gear. the other two larger ones should be replaced at the same time. They are not expensive and I may have some in stock at home.
cscmc1
Thank you, thank you, thank you! I know that the gear in question in missing teeth, and I would be happy to replace the other gears as well. Nakamichi wasn't terribly interested in replying to my inquiries, and the only other shop I have found so far with the parts wants $17 for the gear plus $13 for shipping (!!!). The player is hardly worth that in working order, so I am hesitant to spend big-$ on fixing it. It IS a nice unit, however, and I'd very much like to see it in operation again.
Westley
Hi, I have both gears in stock. As I have not used any since 1996,
I will be glad to send them to you if you will email me your address to send them.
cscmc1
Thanks, Westley! I tried to email you, but the user CP said you specified no email. My email address is my username at yahoo.com
Do you have a PayPal account? Let me know what I owe you and I'll get it on the way pronto. Thanks a million!
cscmc1
Bump to top... still need these gears or part numbers if anyone can help. Westley -- did you get my email replies? Thanks!
Page generated in 0.031897068023682 seconds with 16 queries,
spending 0.00707889 doing MySQL queries and 0.02481818 doing PHP things.
Copyright ©1999-2009 diyAudio.com
