diyAudio.com diyAudio Forums Archive > Top > Source > Digital
cd-rom into standalone transport, how-to??? - Click HERE for Original Thread
rwagter
Following this subject:
http://www.diyaudio.com/forums/show...1270#post121270
I'd like to convert an old cd-rom into a serious cool looking transport like this:
I only don't have this cd-rom player (creative infra 52x) but a normal IDE (generic samsung40x) and one with SCSI (ricoh 6200 (saturn main board)).
Both are disassebled but not starting. A reason for that is that the creative has a remotecontrol and can be used as a standalone.
My cd-rom players don't have this.
My question:
Does anybody know which leads on a EDI or SCSI connector I have to shortcut/give a pulse in order to start the damned thing???
Ralph
Sparhawk
quote:
Ralph
It's not quite that easy, unfortunately. You need to send commands over the IDE or SCSI bus, which will require a microcontroller. Some generic drives have very basic transport controls on the front panel for playing audio CDs (usually just start/stop, sometimes track skip).
rendisha
http://home.kimo.com.tw/d8831152/
Guess what... it's also in taiwanese :clown:
rwagter
Great
who is willing to translate this and write a comprihensionable
manual for the reward of a nice bottle of bourgondie red wine send to you (all over the world
Anyone???
Ralph
Jarno
Looked at the website, schematics are in English, so are the files which contain the programming (*.asm).
There's also an e-mail address in one of the files.
Is there anybody out there who can explain in plain English how all of this works, I for one am very interested (I would prefer the thing without a display, however).
Greetings,
Jarno.
Spherion
Hello,
Well, I am working on using a cd-rom as a transport for my next Cd player. I am using a Plextor UltraPlex 40Max.
At the moment I am using dac form plextor, it feeds custom analog ouput stage consisting of OPA627 and BUF634.
Well, as for controlling the whole thing it's hard, because
U need to have some kind of microcontroller if U want to have
more fuctions than just play/stop/eject.
The sound is astonishingly good. I'll post some thoughts in the
morning 'coz I've just come back from party ;)
Adam
PRBS
Ralph,
I really want to help you. But you do not answer my question in Pass Labs forum. Did you put a disc clamp when you play? There is a disc clamp inside CD-ROM. If no disc clamp, CD-ROM would not start.
One more thing, there is also a limit switch inside CD-ROM. It activates when CD-ROM cassette open/close. You have to short or open it. You have to make sure the limit switch status same with when cassetee is closed.
You need not connect IDE or SCSI interface. CD-ROM can work like a generic transport. For convenience, choose two buttons type CD-ROM. i.e. play/forward and stop/open/close. Otherwise you would not move ahead to other tracks. Good luck.
SkinnyBoy
You can also get CDroms with all 5 function buttons. Play/Pause, Stop, Next, Previous, Eject.... My friend has an old 12X like this... Not sure if it worth getting it from him though, the laser is on its way out.. :P
Spherion
Hello,
I am playing with a SCSI Plextor CD-ROM...there are some of my thoughts:
- choose a CD-ROM with at least two control buttons (play/next and stop/eject)...don't play with el-cheapo units, it doesn't make
sense, it really makes no difference, whether it has digi-out,
or not. At long last, U will have to open it and 'work' on the internal circuitry, it ALWAYS needs some tweaks
- if U want to access more advanced functions of a CD-ROM U have to use a PC or build some circuitry around a microcontroller
chip, well this can be tricky, especially bearing in mind that U may
have to WRITE some software code, usually in C or ASM.
I have no experience with IDE CD-ROM since the unit I am
working on is a SCSI unit, I despise IDE bus actually :cool:
As for SCSI, there are some links:
http://www.tldp.org/HOWTO/SCSI-2.4-HOWTO
http://www.t10.org/
http://www.tldp.org/HOWTO/SCSI-Generic-HOWTO
http://www.tldp.org/HOWTO/SCSI-Programming-HOWTO.html
Hope this helps. I know that I have to restate some of my assumptions, so I am in no position to say anything about programming the whole damn thing. What I know is that I'll
probably use 'Common Access Metod', instead of Adaptec's
ASPI for controlling the Plextor. Now I am looking for a serious
microcontroller with relevant development kit...and BIG red
illuminated display like in Mark Levinson's NO.390...anyone
has the idea of where to get these?
Any suggestions, comments, encouragement welcome :)
With best regards,
Adam
rendisha
About the site I posted, member called nFORCE (who first posted this link) offered his help in traslating it to english, but he never did it. Why... I don't know.
There's link to the forum on Yahoo about this project and it's half in Taiwanese, half in what might be called English but, IMHO, only understandable to those who wrote it. There might be some errors in the code or just people don't doing it the right way as I see, so help about translating it would be appreciated :confused:
fmak
The Creative can be bought from farnell .com Offer Issue 26 for £25. but doen't have an accurate clock.
The Taiwan Website is asking for help in debugging his software!
rwagter
PRBS,
sorry for not answering your questions in the other thread but here they are
1. I tried the clamp but it didn't matter
2. I tried all cominations of the momentary switch but that doesn't seem to matter either.
All chips/ic's are plastic covered so I can't ground them manually as you did.
My next step:
Dissasemble an old cd-player and rebuild it. I know for sure that it has got a start and stop button etc.
Ralph
p.s. lucky me for holding on to old junk
ditter
my project support all standart functions button
Play, Pause, Stop, Forward (+5 sec), Backward (-5 sec), Next, Previous, Load/Eject
and also support
Preview (firt 10 sec), Single, Repeat, Random & CD-TEXT (with scrolling )
& infrared remote control :)
Spherion
Hello Ditter!
Any details on your project? ;)
Adam
ditter
datasheet
binary data for AT89 without CD-TEXT options :(
norvbul
Hello Ditter
could you provide more details on your project besides the data and codes
rwagter
Norvbul,
when you put ditter's website adress in babelfish:
babelfish
and let it translate russian->english you get a instant readable
translate of ditter's website with loads of info ;)
Ralph
p.s.
the adress
http://audio.neora.ru
Jarno
Hello all,
I hadn't heard of babelfish previously, but it is very cool indeed.
For some reason, I didn't manage to find the schematics though, seems some of the PDF are corrupt and there is a picture that will not load.
Greetings,
Jarno.
Jarno
Oops, spoke too soon. Did manage to get the PDF's.
Greetings,
Jarno.
rwagter
Read:
"the hitchhiker's guide to the galaxy" and you know all about babelfishes and lot's more ;)
Ralph
costiss
so.. suppose u build it.. can one add a clock on it to correct the jitter.. cd roms have nice error correction.. but not so nice clocking.. add a clock like.. say a kwak clock
scraggles
Another site with a CD-Rom based transport is:
www.diymania.net
This one's all in Korean though. You can post questions to the aptly named foreigner QA board there. These guys have built some cool stuff, it's worth a look around the projects page.
Here's a pic:
Jarno
Very nice diy stuff indeed. The only thing I don't get is why these guys build such quality stuff with high-end aspirations and still have a Marshall Valvestate combo for a guitar amp.
Guess his next project is a decent all-valve guitar amp.
Jarno.
capslock
Hi Ditter,
will the code with CD-Text be available at some point?
On a side note, does anybody know how to extract the CT-Text data from an S/PDIF interface receiver? I have not even been able to find any documentation on how it is coded into the subcodes.
Eric
Page generated in 0.05670690536499 seconds with 17 queries,
spending 0.00719023 doing MySQL queries and 0.04951668 doing PHP things.
Copyright ©1999-2009 diyAudio.com
